Activity Forums Apple Final Cut Pro FCPx & Apple Scripts
  • FCPx & Apple Scripts
    Posted by Alex Partington on April 25, 2015 at 11:04 am
    Hiya,
    I’ve used the following script to create an iMessage when opens.
    tell application “Messages”
    send “FCPx has succesfully exported” to buddy “44777777777 of service “SMS”
    end tell
    This app should open when final cut pro has finished exported, because I’ve asked FCPx to open with this app, but it doesn’t do a thing.
    Any thoughts?
    Thanks.
    Alex Partington replied 11 years, 4 months ago 3 Members · 4 Replies
  • Jeff Kirkland
    April 25, 2015 at 8:05 pm
    I’ve in,y got the usual app debugging thoughts…
    I guess first question is does FCpX successfully launch other apps? If so, then does yor script work when launched on its own? If so, then I have no idea. Maybe check that your script is saved as an app rather than a script?
    I wrote something similar a while back although I haven’t used on a while. I used Automator and the notification centre to show the alert and Growl/Prowl to display the alert on my iPhone.
    Probably not much help but unless some Yosemite update has changed the way your script execute, it should work for you.
    Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
    http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland
  • Michiel De leeuw van weenen
    April 26, 2015 at 6:29 pm
    – You saved the script in file format ‘application’? (uncheck the options ‘Show startup screen’ and ‘stay open after run handler’
  • Alex Partington
    April 28, 2015 at 12:25 pm
    Hiya, yup, they’re both unchecked.
  • Alex Partington
    April 28, 2015 at 12:28 pm
    Thanks for the reply.
    FCPx successfully launches quicktime as standard and the script does work on it’s own from the programme its self
