Activity › Forums › Apple Final Cut Pro › FCPX animated garbage masks
Posted by Morten Berg on August 31, 2014 at 2:20 pmAnyone got the latest update on animated garbage masks.
I asked about a year ago and was recommended different plug-ins.
Now I want to revisit this subject, so any advice?
(I know several other applications is made/better for this but this is just for splash-and-dash offline edits)
ThanksBret Williams replied 12 years ago 4 Members · 7 Replies -
Oliver Peters
August 31, 2014 at 2:49 pmPlug-ins.
Oliver
Orlando, FL
http://www.oliverpeters.com -
Oliver Peters
August 31, 2014 at 2:55 pmCoremelt’s SliceX and TrackX. You are probably best to do it separately in AE or Motion and then bring the rendered clip into X.
Oliver
Orlando, FL
Morten Berg
August 31, 2014 at 3:01 pmThanks,
I suppose Motion does not intigrade with FinalCut anymore but has become stand-alone, right?
Noah Kadner
August 31, 2014 at 6:47 pmYou don’t have send to Motion from FCPX but you can design any desired transition/filter/generator in Motion and use it in FCPX. So integrated yes, same as in 7, not exactly.
Noah
FCPWORKS – FCPX Workflow
Call Box Training -
Morten Berg
September 1, 2014 at 5:19 pmThank you for advice, I tried a couple of the plugins but think I will end up using Motion or even AE!
Bret Williams
September 2, 2014 at 3:27 amA good mask plugin – https://www.fcpeffects.com/collections/new-stuff/products/advanced-masking-tools-2
They’re having quite the sale right now. 16 plugins for $156 if you use the 75% off $599 code. They have quite a lot of good plugins.
