Activity › Forums › DaVinci Resolve › FCPX and Resolve vectorscopes showing different images
  • FCPX and Resolve vectorscopes showing different images
    Posted by Masha Troitskaya on December 16, 2016 at 8:56 pm
    Hello. I’m new to Davinci Resolve. I made a test video file in FCPX just to be shure I see it the same way in FCPX’ and Resolve’s vectorscopes. And there is a difference between what I see. How can I fix that?
    Thank you.
    10879_skinprores.mov.zip
    Glenn Sakatch replied 9 years, 9 months ago 4 Members · 4 Replies
  • Simon Ubsdell
    December 16, 2016 at 10:35 pm
    In Resolve, if you select your clip and right click and go to Clip Attributes and set it to Video (or Auto) rather than Full, you should see the same result as you are seeing in FCP X.
    Simon Ubsdell
    tokyo productions
    hawaiki
  • Masha Troitskaya
    December 16, 2016 at 11:32 pm
    Unfortunately it doesn’t work. Thank you.
  • Marc Wielage
    December 17, 2016 at 9:40 am
    I would check normal SMPTE bars and see if they align in the calibration boxes.
    I also don’t recommend internal scopes for anything — you’ll get more accurate results (in general) with external scopes.
  • Glenn Sakatch
    December 17, 2016 at 4:19 pm
    This tells me FCPX is either interpreting the footage wrong, or doing something to it internally.
    (This also tells me you might want to be careful if coloring in FCPX)
    “How do I fix it?” Don’t color in FCPX?
    Glenn
