Activity Forums Apple Final Cut Pro FCPX and Compressor 4 – where are the detailed settings?
  • FCPX and Compressor 4 – where are the detailed settings?
    Posted by Olly Lawer on March 5, 2012 at 4:08 pm
    I had my workflow nicely worked out with FCP 6 for YouTube and would export H.264, 8000kb/s for download.
    However, I cannot for the life of me figure out how to go about this with FCPX? I just paid for Compressor 4, thinking the option would be there, but it isn’t!
    Any help appreciated and sorry if this has been covered already – I saw similar posts but none that answered by question.
    Olly Lawer
    Jeff Greenberg replied 14 years, 6 months ago 4 Members · 6 Replies
  • Jacob Lanum
    March 6, 2012 at 2:37 am
    If you want options your using the wrong program
  • Nick Ring
    March 6, 2012 at 3:59 am
    The settings window in Compressor has a search bar. Does entering “h.264” bring up a setting that would make a good starting point for you? Also, with that search bar empty, click on the button to its immediate right (“+” with a dropdown). There are a variety of other presets available there.
    You should also be able import Compressor 3.5 custom presets into 4. I have not tried the method in this link, but maybe it will be helpful: Moving Compressor 3.5 Custom Presets to Compressor 4
    -nick
  • Nick Ring
    March 6, 2012 at 4:03 am
    Compressor 4 is not particularly different from Compressor 3.5. Did you feel the same way about earlier versions of Compressor? What encoding program do you generally use/prefer?
    -nick
  • Jacob Lanum
    March 6, 2012 at 5:18 am
    I use sorenson squeeze.
  • Olly Lawer
    March 6, 2012 at 11:07 am
    Thanks. Found a solution. I select YouTube as the preset (interestingly it was already using settings of 8000kbps so I was along the right lines!) and changed to 1080 and download then saved as a custom setting. Worked a treat. I can now select the setting straight from FCPX.
    I must say I am liking FCPX better and better.
    Olly Lawer
  • Jeff Greenberg
    March 6, 2012 at 3:03 pm
    Send it over to compressor.
    Use compressor to pick whatever setting you want and customize it (just like in compressor 3)
    Apple has a youtube preset set to 20,000k.
    Best,
    Jeff G
    Certified Master Trainer | Adobe, Apple, Avid
    You should follow me (filmgeek) on twitter. I promise to be nice.
    My book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
    Lynda.com – Compressor Essentials 3.5 and 4
    Contact me through my Website
