Activity Forums Zaxwerks FCPX adding Frames to Imported Pro8.0.2 Lossless file
  • FCPX adding Frames to Imported Pro8.0.2 Lossless file
    Posted by Aaron Freeman on November 7, 2014 at 4:43 pm
    Ok here’s what I tested:
    I’m outputting from Pro8.0.2 a HD 1920×1080 29.97p lossless file. I went frame by frame with that file in quicktime 7 and found no extra frames.
    I checked both the multithreaded render and the non-multi render. both seem fine. and the QT7 inspector says its a 29.97fps clip.
    The strange part is when I import this file to a 29.97 HD FCPX timeline, In the timeline Final Cut is adding one frame around every second creating a two frame pause.
    I can’t seem to change the FCPX project to a 30P.
    If you have final cut X please test this!
    So I imported the lossless Pro8 29.92fps file into Adobe Premiere CC 2014.1 version, and Premiere says the file is a 30p fps and creates a 30p timeline.
    It plays smooth. I then change the Adobe timeline setting to 29.97. It displays the clip as now being 29.97 too. When playing through timeline frame by frame
    in either 30p or 29.97p. there are no added frames. So Adobe seems to handle the issue. However I didn’t export the timeline.
    I then bring the same lossless clip into Apple’s Compressor and it says the clip is a 29.942 fps. (What is that?) Explains FCP adding frames?
    Adobe Encoder Says the clip is 30fps
    MPEG Streamclip Says the Pro8 lossless clip is 30p.
    To double check Streamclip, I loaded my xdcam footage at 29.97 and prores 422 clips at 29.97 and they showed the correct fps.
    Something very strange is going on either with the Pro8 exporter engine or Apple’s software is having issue reading the clip properly.
    THIS CLIP IS FROM THE FCPX TIMELINE:
    Matt Rhodes replied 11 years, 10 months ago 2 Members · 5 Replies
  • Aaron Freeman
    November 7, 2014 at 5:50 pm
    Another test:
    I created a new 30P Event in FCPX and 30p Timeline.
    Imported the 29.97p Pro8 Lossless clip and (drumroll), FCP doubled the first frame causing a
    jitter in the beginning but the rest played smooth. After Trimming the first few frames
    the jitter is gone.
    But still the issues remain then: Why is FCPX seeing a 29.97 ProAnimator clip as a 30P?
    and why is it adding frames in either 30p or 29.97 timelines?
    Why is Compressor seeing the Pro8 clip as 29.942fps?
    I’ve double checked to make sure the Pro8 timeline is in fact 29.97 and it is.
  • Matt Rhodes
    November 7, 2014 at 6:23 pm
    Hi Aaron.
    We’ll look into this and do some tests.
    Matt Rhodes
    Zaxwerks, Inc.
  • Matt Rhodes
    November 7, 2014 at 6:31 pm
    Hi Aaron.
    After some quick checking, it looks like there’s a bug when outputting the Lossless format at 29.97fps.
    The H.264 output seems to have the correct fps of 29.97, but the Lossless version needs to get fixed.
    I’ll let you know when we have a fix.
    You’re using ProAnimator on the Mac, correct?
    Thanks.
    Matt Rhodes
    Zaxwerks, Inc.
  • Aaron Freeman
    November 7, 2014 at 6:43 pm
    Matt,
    Yes I’m running an old Mac Pro 4,1 (4) core 2009 with 32gig, OS 10.9.5
    Thanks for looking into this.
    _Aaron
  • Matt Rhodes
    November 8, 2014 at 1:16 am
    Hi Aaron.
    I believe I have a fix for you.
    Can you please send your email address to: matt at zaxwerks dot com
    Also let me know if you own the PA standalone, the PA After Effects plug-in, or both.
    Thanks.
    m
