Activity › Forums › Creative Community Conversations › FCPX 10.3.3 released
  • John Young
    April 14, 2017 at 3:00 am
    Yes. The chicklet bug drives me insane. I also have trouble with clip names disappearing in list view.
  • Tony West
    April 14, 2017 at 3:20 am
    [Andy Neil] “the most annoying bug I’ve encountered is that occasionally when working, the play (spacebar) and play forward (L) keys stop working in the timeline. I have to select a different window like the event browser”
    I have seen this
  • Andy Neil
    April 14, 2017 at 4:48 am
    [John Young] “I also have trouble with clip names disappearing in list view.”
    Yes! I have that too. Minor annoyance, but still an annoyance.
    Andy
    https://plus.google.com/u/0/107277729326633563425/videos
  • Scott Witthaus
    April 14, 2017 at 9:34 am
    Thanks for the list of bugs and “annoyances”. Will keep an eye out. I assume these all went to product feedback?
    Scott Witthaus
    Owner, 1708 Inc./Editorial
    Managing Partner, Low Country Creative LLC
    Professor, VCU Brandcenter
  • Robin S. kurz
    April 14, 2017 at 9:59 am
    [Jeremy Garchow] “No linkable release notes that I can find, yet.”
    When in doubt: App Store. 😉
    For prosperity:
    Final Cut Pro X
    What’s New in Version 10.3.3
    • Ability to expand the width of the Inspector to view and adjust effect parameters
    • Fixes issues with updating older libraries
    • Faster redraw of audio waveforms when using clips that are being imported while recorded to disk
    • Diamond icon in the Timeline Index to show when the user has modified display of roles in the timeline
    • More color options in the Role Editor
    • Reveal in Browser correctly displays the location of the original clip in the browser
    • Support for Canon Log 3 and Sony S-Log3/S-Gamut3 log processing
    • Resolves an issue in which the viewer could occasionally disappear when exiting full screen
    • Resolves issues in which Share to DVD could become unresponsive
    • Improves font quality of DVD menu and chapter titles
    • Improves image quality when creating a DVD
    • Enhanced DVD User dialog messages with embedded links to documentation
    Motion
    What’s New in Version 5.3.2
    • Fill filter lets you quickly fill an entire layer without requiring a separate layer and mask
    • Missing plug-ins are identified correctly when opening a project
    • Midtones are represented accurately when using the Color Balance filter
    • Improves stability when scaling shapes from or to zero
    • Improves stability when working with duplicated rigged filters and behaviors
    • Fixes a stability issue that could occur when using keyboard shortcuts while a keyframe is selected in the Keyframe Editor
    • Improves stability when moving the cursor across markers during playback
    Compressor
    What’s New in Version 4.3.2
    • Command line options for monitoring job status
    • Dithering option adds noise to images to minimize distracting patterns such as color banding
    • Option when creating iTunes Store package to identify health warning text as required by Indian law
    • Improves watermark image quality
    • Support for animated PNG and animated GIF image sequences
    • Timecode filter is accurately displayed against drop-frame media
    • Fixes sync for audio transcoded to AC-3
    – RK
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
  • Oliver Peters
    April 14, 2017 at 2:57 pm
    [Scott Witthaus] “Anyone else getting bugs like this?”
    Yes.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Mark Dobson
    April 14, 2017 at 4:10 pm
    I thought it was just me that found the Titles, SFX and Generator move to the Event Browser really annoying!
  • Doug Metz
    April 14, 2017 at 6:43 pm
    [Craig Shields] ” …the Flow transition doesn’t look as good. Now it looks like a crappy dissolve. A previous render under 10.3.2 looks smooth, this doesn’t.”
    I noticed this too. Even if I modify the in/out on either side, or if I change the duration of the transition, it still isn’t as good as it was in 10.3.2. Not cool.
    Also noticed that audio clips assigned the ‘Music’ role now fade up – no matter where you start playback in the timeline. Not exactly thrilled with this, either.
    *Edit* Trashed prefs and relaunched… music fade-up is now back to previous behavior.
    Doug Metz
    Anode
  • Douglas K. dempsey
    April 14, 2017 at 7:22 pm
    I also see interface bugs, such as: When in Colorboard, the headings for Color, Saturation, Exposure will suddenly go blank on the unchosen tab, then when I click on a “blank” tab, that one appears and the others go blank.
    It’s of no consequence to work, of course, but along with various other items mentioned here, which I also see, makes me nervous as UI oddities usually point to some underlying instability.
    A couple of times, working with stock titles and effects, when I applied an effect (“Underwater”) to a stock title effect (“Pixie Dust”?) … the effect worked, played back once or twice … then hung up, necessitating a force quick. When I re-opened and tried to play the effect, same result … had to delete the effect.
    Again, not profound … and I can understand that applying an animated effect to an already animated title might be asking too much, as the math fights itself. Still, instability here and there lately.
    Doug D
  • Gerry Fraiberg
    April 14, 2017 at 9:09 pm
    [Craig Seeman] “I don’t see it mentioned but the Audio FX icons have changed.
    Perhaps a sign of things to come?
    – Gerry Fraiberg
    Media Handyman – videographer, editor, photographer, voice over artist.
    http://www.visionandvoice.ca
Page 3 of 6
