Activity Forums Apple Final Cut Pro FCPX 10.3.2 is released
  • FCPX 10.3.2 is released
    Posted by Andrew Richards on January 19, 2017 at 10:07 pm
    Release notes:
    • Ability to add custom folders of audio files to the Sound Effects browser
    • Using ripple delete on audio-only clips no longer disables the selected range
    • Audio meters retain custom width after relaunch
    • Improves responsiveness when editing very long projects
    • Improves performance when exporting H.264 files and changing frame rate
    • Exporting ProRes 4444 files with transparency using Compressor creates a correct alpha channel
    • Fixes an issue in which adjusting the line spacing of multi-line titles only applied to the first line
    • Fixes an issue in which secondary storylines with mixed roles could overlap in the timeline
    • Fixes an issue that could prevent burning Final Cut Pro projects to DVD via Apple USB SuperDrive
    Best,
    Andy
    Jason Jenkins replied 9 years, 7 months ago 7 Members · 8 Replies
  • 8 Replies
  • Jeremy Garchow
    January 19, 2017 at 10:10 pm
    Hey hey! Bug Fixes!
  • Bill Davis
    January 19, 2017 at 11:53 pm
    For me, two things stand out about the update.
    Range select then hitting “delete” returns to the “kill and collapse” audio behavior from before 10.3
    And I just heard from some of my friends in large FCP X based facilities in Europe – and they tell me X performance for large operations and facilities has gotten an VERY significant speed boost via this update.
    So the network and movie folk should be smiling today.
    Good news all around the X community today!
    Creator of XinTwo – https://www.xintwo.com
    The shortest path to FCP X mastery.
  • Andy Neil
    January 20, 2017 at 12:12 am
    Thank goodness they fixed the audio meters. I know it’s a small thing, but that bug was driving me up the wall.
    Andy
    https://plus.google.com/u/0/107277729326633563425/videos
  • Oliver Peters
    January 20, 2017 at 2:27 pm
    How do you add custom SFX folders to the Sound Effects browser? I’m seeing the solution is to add the SFX to your hard drive library folder. That hardly seems like a new feature and isn’t exactly what the release bullet point implies. Is that really the correct way?
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Orlando Ferreyra
    January 20, 2017 at 7:53 pm
    Hey All,
    Anyone still seeing the Clip Appearance functions still reverting back on restart? I set it to see full clip not 10 seconds or 30 seconds but whenever I close it, FCPX it goes back to showing 30sec of clip… Hope I’m making sense… I was hoping this bug was going to be addressed. At least audio meters width is staying put now… ☺
    Thanks all
  • Orlando Ferreyra
    January 21, 2017 at 4:40 pm
    Hey All,
    Thanks all
  • Oliver Peters
    January 21, 2017 at 4:54 pm
    [Orlando ferreyra] “Anyone still seeing the Clip Appearance functions still reverting back on restart? I set it to see full clip not 10 seconds or 30 seconds but whenever I close it, FCPX it goes back to showing 30sec of clip… Hope I’m making sense… I was hoping this bug was going to be addressed”
    There appear to be a lot of state-persistence issues that have not been fixed. For example, if I set the browser in list view to a custom column layout, group by criteria other than date, or set it to filter for Favorites, upon relaunch, none of that has stuck.
    – Oliver
    Orlando, FL
  • Jason Jenkins
    January 24, 2017 at 12:06 am
    Unfortunately, they didn’t fix the color problem with mp4 footage.
    Jason Jenkins
    Better Video Starts Here
