Activity › Forums › Apple Final Cut Pro › FCPX 10.3 Bugs
  • Jeremy Garchow
    November 9, 2016 at 3:22 am
    On the new user or your old user?
  • Kripá Pizzorno
    November 9, 2016 at 7:27 am
    Not rendering clips with Optical Flow applied is not a new issue for 10.3. I experience that on a daily basis in 10.2.3, to the point where I’m in the habit of exporting master clips just to check that it’s free of analysis errors.
    2015 5K iMac, i7 4GHz, 2GB GPU, 16 RAM, 512 SSD
  • Emma Crouch
    November 10, 2016 at 1:34 pm
    Whenever I try to copy a clip from one project to another, within the same library, FCPX freezes. There’s no beachball of terror, it’s just completely unresponsive, and I have to force quit.
    This is an old updated library, and programme has crashed completely once. I’m guessing this could be a performance issue, which is frustrating as I’ve already trashed preferences. Has anyone else experienced this?
  • Emma Crouch
    November 10, 2016 at 1:38 pm
    Also, does anyone know where the shortcut is for changing clip speed etc. or have we lost this as a button?
  • Gregor Queck
    November 10, 2016 at 2:07 pm
    Final Cut Pro 10.3 New Features Lesson 1: Exploring the New UI by Ripple Training:
    https://www.youtube.com/watch?v=tTJ6Gmah8n4
    The other one is a bug and you can report it on the feedback-page…
    This bug seems to go away by using the command: File -> Delete Generated Library (Project) Files
    and deleting all render files etc. ……. sometimes………. 🙂
  • Emma Crouch
    November 10, 2016 at 2:49 pm
    Thank you – have reported!
  • Jeremy Garchow
    November 10, 2016 at 5:21 pm
    [Emma Crouch] “Also, does anyone know where the shortcut is for changing clip speed etc. or have we lost this as a button?”
    The button is now underneath the viewer to the left of the timecode. The shortcut is command-r.
  • Emma Crouch
    November 11, 2016 at 1:07 pm
    Brilliant – didn’t see it hiding there at all, thank you.
  • Jeremy Garchow
    November 11, 2016 at 1:27 pm
    [Christian Bille] “I am experiencing a drag-lag. This may be a bug, it sure seems like it.
    When I try to mouse drag a clip, I get a lag of about 2.5 seconds.”
    Trash the entire FCPX cache file and let thumbnails and waveforms rebuild.
  • Taylor Martyn
    November 23, 2016 at 10:12 am
    Most of mine have to do with the new layout features. However, those bugs are causing the app to ‘freeze.’ No spinning beachball, when I go to force quit, it doesn’t show that it’s crashed, it’s just unresponsive. I am using two monitors. 90% of the time I open the app, my second monitor set to show my viewers, is just solid white. I select in the menu to change it to something else, and it all freezes up. But if I select to show the views in my main monitor, I can work, while the second monitor stays white. A few small irritants to do with the layout. The audio meters are huge. So I can slim them down, but when I quit the app and reopen, they are big again. I’m annoyed that I cannot slide my timeline to be the full width of the screen. the only way to do that is to turn off the inspector. I wish I could have the inspector only be the top half, giving room for the timeline. When I did the work around earlier, adding the viewer back to my main monitor, it made the file viewer ‘browser’ very small and gave more room to the list of events/projects, etc. So I grabbed the slider between the to to make the browser larger, it slid over, but when I released the mouse, it bounced back over. Tried a few times with the same result.
    FCPx still has a LONG way to go.
Page 5 of 8
