Activity Forums Apple Final Cut Pro FCPX 10.2 Flash Transition Cutoff
  • FCPX 10.2 Flash Transition Cutoff
    Posted by Andrew Shelton on January 18, 2018 at 10:20 pm
    Hey guys.
    Working with FCPX 10.2. In middle of a project and really don’t want to have to upgrade if that is the issue but working on a project that is 4K 4096×2160. I have a flash transition (FCPX standard version) between two clips and during the transition the flash cuts off so there is a line showing on the left side. Nothing real large but enough to get me going on a rant I guess! The clips can be seen(meaning they fit the dimensions) so it seems to be the transition itself. I have tried other transitions with no issue.
    Any suggestions?
    Andrew Shelton replied 8 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
