Activity › Forums › Creative Community Conversations › FCPX 10.1.2 disappearing projects?
  • FCPX 10.1.2 disappearing projects?
    Posted by Jan c. Botha on July 12, 2014 at 9:13 pm
    I manage a post facility, and we started to converted everything to FCPX in October 2013. I have had two separate incidents since the 10.1.2 update where the editors project would disappear. With the first the editor open his library the next day and we could not find any trace of the editors edit, not even in the autosave. But with the second two days later only half the edit on the sequence disappeared. After relaunching FCPX the rest of the sequence appeared.
    Has anyone else experienced this problem, or know what could be causing this?
    Darren Roark replied 12 years, 2 months ago 9 Members · 18 Replies
  • 18 Replies
  • Oliver Peters
    July 12, 2014 at 10:57 pm
    I’ve seen some weird behavior after upgrading as well, but nothing like that. Make sure you trash all the preferences. Apparently Preference Manager doesn’t get them all, so you have to do this manually. Check in the individual user Library – Preferences folder. Find the Final Cut Pro preference files, trash, empty trash, restart. Not sure if that’s the answer, but it’s worth a shot.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Bret Williams
    July 12, 2014 at 11:21 pm
    Can’t we trash prefs on launch now by holding down something?
  • Oliver Peters
    July 12, 2014 at 11:50 pm
    https://support.apple.com/kb/ts3893
    From the support doc:
    Reset preferences in Final Cut Pro X 10.1.2
    Quit Final Cut Pro X.
    Hold down the Command and Option keys while reopening Final Cut Pro X. A window will appear asking “Do you want to delete preferences?”
    Click Delete Preferences. This command removes the preference files and resets Final Cut Pro X to default settings.
    – Oliver
    Orlando, FL
  • John Davidson
    July 13, 2014 at 4:37 am
    Oh, that’s a good one Oliver. Thx.
    John Davidson | President / Creative Director | Magic Feather Inc.
  • Jeremy Garchow
    July 13, 2014 at 5:17 am
    What hardware are you running this on and if upgraded from older OS, are they clean OS installs?
  • Craig Alan
    July 13, 2014 at 4:43 pm
    Oliver, are you saying this method may not trash them all and therefore use the manual method?
    Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
  • Oliver Peters
    July 13, 2014 at 11:11 pm
    [Craig Alan] “are you saying this method may not trash them all”
    No. When I used Preference Manager to trash the FCP X preferences, it didn’t get them.
    – Oliver
    Orlando, FL
  • Bill Davis
    July 13, 2014 at 11:38 pm
    I find it kind of suspicious that the 10.1.2 release HAD the re-emphasis on the new “clear prefs” keystroke combo.
    Seems like they knew there was something in the new plumbing that was creating issues.
    Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com – video editing curriculum complete with licensed practice content.
  • Oliver Peters
    July 13, 2014 at 11:49 pm
    I’m starting to believe the prefs need to be trashed with EVERY update. I also find some updates cause problems with active productions that are updated. Some are fine, but it’s a pucker factor with large productions every time there’s an update.
    – Oliver
    Orlando, FL
  • Andre Van berlo
    July 14, 2014 at 8:02 pm
    I more or less had the same thing. A project disappeared in FCPX, the folder was still there on the harddrive but somehow the project wouldn’t load. I didn’t have a whole lot of stuff done in that project so I started from scratch. That old project still doesn’t appear in FCPX though, strange bug.
