Activity Forums Apple Final Cut Pro FCPX 10.1.1 XML exchange
  • FCPX 10.1.1 XML exchange
    Posted by Florian Gintenreiter on May 21, 2014 at 7:43 pm
    Hi!
    Can anyone confirm this:
    I have a library, which contains multi clips with 2 camera-angles in them. I edit a project and then export a XML. When I reimport the XML in FCPX the edit imports fine, even the compressor on the audio and audio levels imported, but scaling, positioning, cropping and color-correction information is lost.
    In the same library I tested it with an edit without multi clips and there alle the attributes imported fine, including scaling, cropping, color etc.
    Is this a bug?
    ________________________________________
    Director of Photography, Director, Editor
    Vienna, Austria
    Charlie Austin replied 12 years, 4 months ago 2 Members · 1 Reply
  • Charlie Austin
    May 21, 2014 at 10:05 pm
    [Florian Gintenreiter] “Is this a bug?”
    I think it’s just a limitation in the current version of fcpxml. Hopefully it’ll be improved going forward…
    ~ My FCPX Babbling blog ~
    ~”It is a poor craftsman who blames his tools.”~
    ~”The function you just attempted is not yet implemented”~
