Activity Forums Apple Final Cut Pro FCPX 10.0.6 – Specify Save Location for default destinations?
  • FCPX 10.0.6 – Specify Save Location for default destinations?
    Posted by Chris Good on November 1, 2012 at 3:07 pm
    In FCPX 10.0.6, when I go to Share > 1080P for apple devices, which I use frequently, there is no way that I can find to select where it saves to. It just automatically goes to the Movies folder in my home directory. Has anyone else found a way to edit this?
    -Chris
    Chris Good replied 13 years, 10 months ago 3 Members · 3 Replies
  • Lawrence Eaton
    November 1, 2012 at 3:50 pm
    Chris,
    When I use “FILE>SHARE” or using the “Sharing” icon on the UI, I can specify where I want the file to go after encoding when I click the ‘NEXT’ button.
    This doesn’t sound like the case that you are having though?
    Regards,
    Lawrence
  • Simon Ubsdell
    November 1, 2012 at 5:39 pm
    In the Add to Playlist menu you need to select “Do Nothing” otherwise it will go straight to the Movies* folder without giving you the save options in the Next tab.
    *User/Music/iTunes/iTunes Music/Movies
    Simon Ubsdell
    http://www.tokyo-uk.com
  • Chris Good
    November 1, 2012 at 6:31 pm
    Thank you!!
    -Chris
