Activity › Forums › Apple Final Cut Pro › FCPX 10.0.6 Share to Compressor settings not showing Custom Compressor Settings
Posted by Rocco Richardson on October 30, 2012 at 11:46 pmHello,
Using FCPX 10.0.6 and loving the new share options and ability to share in background, and the speed, however, I am unable to see any custom compressor presets I have created in compressor. has anyone else seend this issue?
Ali High replied 12 years, 8 months ago 4 Members · 7 Replies -
Charlie Austin
October 31, 2012 at 2:05 am[Rocco Richardson] “however, I am unable to see any custom compressor presets I have created in compressor.”
You can click the share button above the timeline, or open the “destinations” preferences tab, and choose “add destination” Then, in the choices you’ll see, double click on “compressor settings”‘ You’ll see all your settings and can then add them to the destinations list. After that they’ll show up in the sharing pop up menu. 🙂
~”It is a poor craftsman who blames his tools.”~
Rocco Richardson
October 31, 2012 at 2:13 amthanks for the reply.
I am able to navigate through all of that, and know how to do it. What my issue is, the custom settings vs. the apple presets that appear when you click on compressor settings within share in FCPX 10.0.6 I have custom settings that I have created in Compressor, that will not show up in the custom settings folder in FCPX. Apple setttings lists 10 groups, Custom Settings lists 0.
Charlie Austin
October 31, 2012 at 2:50 am[Rocco Richardson] “Apple setttings lists 10 groups, Custom Settings lists 0.”
OK that’s weird… All mine showed up after the update… Is it possible you have 2 versions of compressor installed or something?
Alex Gollner
October 31, 2012 at 1:08 pmI don’t have Compressor 4, but if I put my custom Compressor 3.5.3 .setting files into
Users/Alex/Library/Application Support/Compressor/Settings/
I can use them in custom Compressor destinations,
@alex4d
___________________________________________________
Alexandre Gollner,
Editor, Zone 2-North West, Londonalex4d on twitter, facebook, .wordpress.com & .com
Rocco Richardson
October 31, 2012 at 2:58 pmThis problem is still happening for me even after all suggestions. I have FCPX 10.0.6 and Compressor 4.0.5 and I have looked in library/application settings/compressor/settings and all my custom presets are there. I see them in Compressor. I have tried installing FCPX and Compressor from scratch on a different machine, and NO ISSUES, HOWEVER, when trying to uninstall and REinstall on the first machine, still the same issue. How can you COMPLETELY remove FCPX and Compressor as if it was NEVER on your system? I have used FCS remover and it does not seem to work either, since when I reinstall, my previous settings have come back!
My issue is this:
Rocco Richardson
October 31, 2012 at 4:18 pmI Fixed the issue. I went back into FCS remover and this time checked BOTH Compressor 4 AND Compressor 3, I guess for whatever reason some settings were still lingering from that. But after uninstalling completely and reinstalling, I can now see the Custom Settings in the Destinations under share for FCPX.
Ali High
January 23, 2014 at 12:07 pmHi I’ve the same problem with FCPX 10.1 and Compressor 5.1.
Is there any way of getting my custom settings to show without uninstalling and re-installing?
