Activity Forums Apple Final Cut Pro Legacy FCP/P2 24p setup
  • FCP/P2 24p setup
    Posted by Randolph Harrison on December 24, 2006 at 5:57 am
    I’m setting up to cut a small feature using FCP. First time with fcp. The footage is full res HD from HVX200. I have the footage on FW drives but will import them onto a raid 0 array. The DP shot 1080 24p. There are so many settings, I don’t know where to start with all of the preferences and settings. Would appreciate any info. And is the raid system difficult to set up? Thanks in advance.
    Randy
    Randolph Harrison replied 19 years, 9 months ago 2 Members · 2 Replies
  • Shane Ross
    December 24, 2006 at 6:33 am
    Well, choose the DVCPRO HD 1080PA24 from the EASY SETUPS, create a new sequence (trash the other one) and then begin importing.
    Your Raid should be set up as a Raid Stripe, 128k.
    Editing this footage is pretty easy really. So much so that you think that you must be doing something wrong because it is TOO easy.
    Shane
    FCP Preferences set to UNCONTROLLED ADVICE
    Littlefrog Post
    http://www.lfhd.net
  • Randolph Harrison
    December 24, 2006 at 6:44 am
    Hey Shane,
    Thanks for the quick response.
    Randy
