Activity › Forums › Apple Final Cut Pro Legacy › FCPHD, Varicam, FIrestore and field recording of offline video
  • FCPHD, Varicam, FIrestore and field recording of offline video
    Posted by Jim Lindsay on May 1, 2005 at 8:57 pm
    Has anyone edited FCP HD offline using DV .mov files recorded in the field on a Firestore unit piggybacked to a Varicam with a Miranda or Evertz conversion interface? In other words, the DVCPRO HD tape records the HD signal and the Firestore unit records DV files for off-line editing without the need to capture from tape, keeping tape totally “virgin” until online. We’re examining various cost/efficiency workflows for an upcoming heavy-travel Varicam project, weighing the cost of the Miranda or Evertz/Firestore concept vs. an assistant editor capturing from tape with a rented DVCPRO HD deck. Curious to know if the time code generated to the .mov files is a match good enough for a painless online. Also, in situations when shooting in a more controlled environment (soundstage) where a powerbook/firewire drive setup can be used, is there a converter less expensive than the Miranda/Evertz that could provide the same conversion of DVCPRO HD to DV for recording .mov files with timecode (matching the HD tape) on the drive/computer. going from an output on the Varicam to a Firewire connection?
    Jim
    Jim Lindsay replied 21 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
