FCP/DSP workflow for hd
OK,
I am trying to take hd out of a canon 60d, and work it though to final product. I encode it for FCP through my encoder at 1080, mix in fcp, compress ( i have tried h264 and mpeg2) I have set the dsp for hd in preferences, then i load it, build, and burn, and voila, a disk, but it will not play in my player in the living room. disc info reads it as hddvd_ts
All I need is one workflow, on path from the 60D to the DVD – or if it is a player issue, how do I verify that – everything else i put in there plays fine, and im sure big bang theory is 1080 – also plays fine in my g5
