Activity Forums Apple Final Cut Pro Legacy FCP/Compressor issue MPEG-2
  • FCP/Compressor issue MPEG-2
    Posted by Elliot Beach on May 9, 2012 at 12:07 am
    I’m getting a very a annoying issue when using compressor.
    I have a 04:80 second apple pro res export form final cut, which I am then importing into compressor and applying the DVD SD mpeg-2 best quality template so I can burn to a DVD.
    The compression goes through successfully, however when I play the mpeg file through quicktime it takes about 10 seconds to play and says the duration is 2 hours long. The video is there in the first 5 minutes but it keeps going with a black screen for 2 hours. If I try to burn this to disc any other video before it plays fine but when the track with this file comes it does nothing and restarts.
    I’m using the default DVD settings in compressor and have tried high bit rate and lower but still does the same issue. The apple pro res file seems to have nothing wrong with it. Also, if I cut a fragment of the video and export using FCP and compress that it seems to work fine with the correct duration.
    Not sure what the problem is, any help would be great?
    Elliot Beach replied 14 years, 3 months ago 3 Members · 3 Replies
  • Alexander Kallas
    May 9, 2012 at 10:53 am
    Have you set in and out points before export from FCP?
    Cheers
    Alexander
  • Michael Bouley
    May 10, 2012 at 10:47 pm
    Self Contained Export is not a problem. It has always been when I create a reference file by unchecking the self contained box that never works. Tested on two iMacs, Results were black screen with audio or frozen screen 3 seconds in with audio. All audio played back just fine.
    Yep FCP weirdness forces me to switch to Final Cut Pro X. Thank You
  • Elliot Beach
    June 13, 2012 at 10:22 pm
    I ended up sending it straight to DVD Studio Pro which did the compression fine. Not sure why Compressor gave trouble with this one
