Activity Forums Apple Final Cut Pro Legacy FCP+canon MK2+Export Issue
  • FCP+canon MK2+Export Issue
    Posted by Marlon Diaz on May 8, 2009 at 4:10 pm
    im searching for some help here. when i export my timeline sequence which is 15 minutes long montage, using HD video from the Canon 5D Mark2 camera. to a quicktime movie self contained movie from final cut but i end up with a slow and choppy playback movie but on top of that i can’t seem to compress the file with quicktime pro, compressor, or adobe media encoder. the encode process will freeze 2 minutes in.
    i have double checked my settings and everything within final cut and everything seems fine. so my issue is that i can’t export a decent final cut quicktime movie from fcp without it being slow, choppy,and skipy and much less compress the file.
    i running on a macbook pro
    final cut 6.0.5
    Miami, FL
    Marlon Diaz replied 17 years ago 2 Members · 2 Replies
  • Steve Eisen
    May 8, 2009 at 4:28 pm
    16 threads below!!!
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Marlon Diaz
    May 9, 2009 at 8:09 pm
    found this, thought i share.
    Final Cut Prose Episode 2 – Editing Canon EOS 5D Mark II Footage
    https://vimeo.com/1829823
    Miami, FL
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
