Activity Forums Apple Final Cut Pro Legacy FCP+After Effects
  • FCP+After Effects
    Posted by Scott Davis on March 15, 2008 at 6:33 pm
    If I open AE while FCP is open, my whole system lags unbelievably. Only cure is to reboot. Anyone else having this problem?
    FCP 5.1.4
    QT 7.4
    AE 8.02
    OS 10.4.11
    On a MBP 2.16 w/ 2Ghz RAM
    Storage, external SATA and FW
    Thanks in advance,
    Scott Davis
    Scott Davis replied 18 years, 5 months ago 2 Members · 2 Replies
  • Shane Ross
    March 15, 2008 at 6:38 pm
    Not enough RAM for both. OS needs 1GB, FCP needs another 1 to 3GB (which is why 2GB RAM is minimum for running FCP)…and then AE needs some RAM. The slowdown is the system using part of the hard drive as RAM (called VIRTUAL RAM)…and yeah, it slows down things terribly.
    Shane
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.LFHD.net
    Read my blog!
  • Scott Davis
    March 15, 2008 at 6:47 pm
    Thanks Shane, makes sense. Thought it was an Intel issue as my trusty ole’ G5 can run both fine; but it has considerably more RAM.
    Scott Davis
