Activity › Forums › Apple Final Cut Pro Legacy › FCP7/Blackmagic MiniMonitor/no playback on external monitor
Posted by Lisha Rigney on November 26, 2013 at 6:14 pmHello to all,
Not sure what I’m doing wrong but video will not playback on my Boland external monitor. A frame will show on the monitor when parked on the timeline but video won’t play through when playing the timeline. Can anyone shed light on where my settings are incorrect?
Thanks so much,
LishaiMac 3.4 Ghz
FCP7.0.3
OS 10.8.5
Blackmagic Mini MonitorLisha Rigney replied 12 years, 10 months ago 4 Members · 12 Replies -
Shane Ross
November 26, 2013 at 6:35 pmIn the EXTERNAL VIDEO menu…just above the VIDEO PLAYBACK…make sure it is set to ALL FRAMES
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Shane Ross
November 26, 2013 at 6:42 pmIN the Blackmagic preference pane, in SYSTEM PREFERENCES…in the SYSTEM PROCESSING tab…are ALL OUTPUTS active?
Shane
Little Frog Post
Lisha Rigney
November 26, 2013 at 6:58 pmYes.
Also, in Final Cut Pro I can click on “Show Current” and the current frame will show on my external monitor.
Shane Ross
November 26, 2013 at 7:18 pmUninstall and reinstall the drivers. Get the LATEST drivers, and install those.
Shane
Little Frog Post
Massimo Alberto croce
November 26, 2013 at 7:58 pmwhat about the canvas in fcp? had the same behaviour? if so,one reason could be that the canvas is in Wireframe mode.
Massimo Alberto Croce
Video Editor, Colorist, Pro Tools Editor
massimoalberto.croce@gmail.com -
Gary Milligan
November 26, 2013 at 8:03 pmI don’t use either FCP or Blackmagic hardware so this is just a guess – according to your screenshots your source is 8 Bit and you’ve selected 10 Bit in the list. Have you tried the 8 Bit setting?
HTH
Gary
Lisha Rigney
November 26, 2013 at 8:15 pmUninstalled and reinstalled the latest driver from the website. Still able to see the frame I’m parked on in the timeline on my external monitor but footage in the timeline will not play in the external monitor.
Lisha Rigney
November 26, 2013 at 8:17 pmFootage plays in the canvas. When I stop playing the timeline the frame I stopped on shows on my external monitor.
