Activity › Forums › Apple Final Cut Pro › FCP7 XML to FCPX XML import???
  • Geert Van den berg
    September 25, 2011 at 3:16 pm
    No not possible (yet). This is a feature that will need to be made by a 3rd party developer. Apple is not going to provide that functionality. At least that’s what their FAQ which was on their website seemed to imply.
    XML is standard (text based and humanly readable) but the way different applications and vendors use it can vary per application. FCP7 XML is just one way that apple has used XML.
    Now with the new update Apple has also posted a guide for developers how the new XML works. A similar guide for the old version also exists. So there probably will be someone that will delve in and create something. It’ll be quite a good move business wise to code something like that.
  • Craig Seeman
    September 25, 2011 at 6:39 pm
    [Geert van den Berg] “This is a feature that will need to be made by a 3rd party developer.”
    CatDV. Import FCP7 Sequence XML, export FCPX XML. Awkward but there have been reports that it does work. It’s apparently just sequences, not entire projects.
    Given the above, I suspect there will be further progress by third parties.
  • Stan Johanssen
    September 27, 2011 at 12:33 am
    I’m working on a online FCP7 <-> FCPX XML converter, but the XML was a bit more complicated than i first thought so i might take some time.
    The dev. version i work on “kind of works” but the generated (converted) XML are not good enough yet.
    The way it works are simply that “user” uploads the XML from FCP7 or FCPX and gets a download dialog for the new XML file. I hope i can have it finished an online during this week.
  • David Bryen
    November 21, 2011 at 10:48 pm
    has this issue been resolved? I want to bring a Final Cut Pro X project into FCP 7. I know this seems like the wrong direction but…I tried xml.
    db
  • Javier Sanchez
    November 21, 2011 at 11:02 pm
    Use resolve Lite to make the conversions of XMLs
    Regards
  • Steve Connor
    November 21, 2011 at 11:41 pm
    Or buy X27!
    “My Name is Steve and I’m an FCPX user”
  • David Bryen
    November 22, 2011 at 2:16 am
    I’ll give that a try. I’ve been meaning to try resolve.
    db
