Activity › Forums › Apple Final Cut Pro › FCP7 XML to FCPX Kinda works using CAT DV
  • FCP7 XML to FCPX Kinda works using CAT DV
    Posted by Greg Jones on September 21, 2011 at 7:20 pm
    So I exported out an xml from Final Cut Pro 7, opened it in CATDV trial version and clicked on ‘Send to Final Cut Pro X’. Alas my sequence opened up. Now a quarter of my clips didn’t show up, but the one’s that did show up are in the correct order. So I think if someone out there with some programming knowledge spent some time, they could make it work.
    Greg Jones
    D7,Inc.
    Orlando,FL. 32837
    https://www.d7-inc.com
    Matthew Stamos replied 15 years ago 2 Members · 1 Reply
  • Matthew Stamos
    September 24, 2011 at 5:56 am
    Can you send a copy of the two xml files to support at Squarebox? That would be great I suspect there will be a number of anomalies but then again it might be something simple. There are a number of preference settings in CatDV that could impact this process depending on the versions of FCP and CatDV.
