Activity › Forums › Apple Final Cut Pro Legacy › FCP7 workflow HD to SD scaling with zoom
  • FCP7 workflow HD to SD scaling with zoom
    Posted by Anmol Mishra on December 8, 2011 at 6:50 am
    I have to make a showreel for some dancers. I filmed them in 1080p25.
    I converted it to cineform using Remaster (I’m working on OSx Snow Leopard). I can use Prores using MPEG streamclip if needed.
    I setup a project with custom 854×480 (for youtube 480p). I deselected User Preferences -> Editing -> Always scale clips to project size
    I used the wireframe to resize the clips and move them so the dancers were filling up the frame (that was requested of me).
    Now I hit the various problems that FCP has with scaling – aliasing artifacts.
    People have posted that its better to use the scaling algorithms from MPEG Streamclip and other tools.
    Unfortunately as I am doing a zoom and move in the same frame, I am stuck using FCP as an editor – unless someone shows me another tool where this could be done.
    So how do I avoid FCPs crappy downscaling algorithms and manage to finish this frustratingly long project ?
    Jeff Meyer replied 14 years, 9 months ago 3 Members · 3 Replies
  • Chris Tompkins
    December 8, 2011 at 1:31 pm
    You are better off editing @ the full res.
    Shot 1080 – edit 1080
    Export a “Current Settings” master.
    Use that file to drop into your compression program to create your various deliverables.
    Chris Tompkins
    Video Atlanta LLC
  • Anmol Mishra
    December 9, 2011 at 4:35 am
    I am using the extra resolution for framing, and using 100% would get me too close.
    Is there another option ?
  • Jeff Meyer
    December 10, 2011 at 5:44 am
    Did you change the Motion Filtering Quality in the Video Processing tab of the Sequence Settings to Best?
