Activity › Forums › Apple Final Cut Pro Legacy › FCP7: Without Mouse- Selecting/Switching multicam timeline clip
  • FCP7: Without Mouse- Selecting/Switching multicam timeline clip
    Posted by Max Steve on December 5, 2013 at 8:26 pm
    Hi All, I work on FCP7.
    My project basically comprises 6 layers of video and 6 layers of audio with one master cam layer.
    Hence my edit workflow is usually hitting space bar for play, when reached at desired point hit space bar again, press control +v to place a cut point at play head position and then continue ahead further in order to clean the NG footage.
    In the above workflow I also switch between video layers (multi cam clips, cam 1,2,3,4,5 etc) with option+s while clicking that clip, and cut/switch to the desired clip with control+v.
    My Query: –
    Now in the above discussed workflow I want to avoid mouse intervention, which is required for clicking the desired clip/cam while selecting or switching to it.
    I want to switch to the cam layers up or down with keyboard while it is still selected. So that if desired, I can able to switch on it with option+s and place a cut point on it with control+v.
    The idea is to be able to switch between multicam layers and select them without mouse help.
    Thanks in advance.
    Max
    Misha Aranyshev replied 12 years, 9 months ago 2 Members · 1 Reply
  • Misha Aranyshev
    December 8, 2013 at 10:31 am
    If you are on full-sized keyboard with a numeric keypad type Option–(NumPad)Zero then Command–(NumPad)Zero to deactivate Auto-Select on all tracks. Then type Command-(NumPad)1 to activate Auto-Select on V1. Control-V won’t affect other tracks.
    By the way, why don’t you create a real multi-clip in the Browser first and then drop it to the timeline? It will give an N-up display and keyboard shortcuts for switching between “cams”.
