Activity › Forums › Apple Final Cut Pro Legacy › FCP7 Trouble Importing Stills
  • FCP7 Trouble Importing Stills
    Posted by David Burkart on August 19, 2010 at 1:11 am
    Just got FCP7. Have used several previous versions.
    When importing stills, the program automatically rotates all stills to essentially fill the 16:9 frame.
    As a result, all of my vertical stills are flipped on their sides. I know how to rotate them each manually, but this messes with the motion controls – can’t do what I want.
    Anyone know what import settings I need to change? Tried Google and couldn’t find the issue.
    “A song is an excuse to go to a chorus, and a chorus is an excuse to go to a breakdown.”
    David Burkart replied 16 years, 1 month ago 4 Members · 7 Replies
  • 7 Replies
  • Rafael Amador
    August 19, 2010 at 1:29 am
    Never heard of that behave in FC.
    Anyway try un-checking in the Preferences “Scale Clips to Sequence” (Users Prefs> Editing).
    rafael
    http://www.nagavideo.com
  • David Burkart
    August 19, 2010 at 2:45 am
    Thanks.
    Still can’t figure it out, but it’s definitely something to do with the image, not the FCP settings. Imported a vertical image from another batch of images and it came in just fine.
    If anyone has any idea what properties that image possesses to make it import horizontally, let me know! Shot with a Nikon D5000.
  • Shane Ross
    August 19, 2010 at 5:29 pm
    FCP doesn’t do this. I know Avid does, but FCP does not stretch or scale still images to fill the frame. Never heard of this behavior, and in my 5 years editing with FCP and using stills, I have not seen it.
    Trash your preferences…might be an issue.
    #44: FCP acting weird – Trash Prefs
    Shane’s Stock Answer #44: FCP acting weird or unusual. Just not like is normally should
    If the program was working fine, and now isn’t, or just isn’t working the way it should, the first things to do are:
    1) Trash your FCP preferences. Download the Preference Manager from Digital Rebellion: https://www.digitalrebellion.com/pref_man.htm
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    2) Open the Disk Utility and Repair Permissions.
    3) Shut down for 10 min. Go for a quick walk around the block and get SOME exercise today. Come back, turn on the computer and see how things are.
    4) (optional) Do the Hokey Pokey and turn your self about. Results may vary.
    Shane
  • David Burkart
    August 19, 2010 at 5:43 pm
    Hmmm, good advice.
    Tried both of the previously mentioned ideas to no avail – I decided it’s not FCP, but some setting on the camera. Reason: FCP doesn’t react this way to other vertically framed images I have.
    Thanks anyways, I’ll keep this in mind in the future. Cheers
  • Rafael Amador
    August 20, 2010 at 2:50 am
    Perhaps these stills had been rotated somehow previously with other application.
    I would open the stills on PS or even with QT and save them again.
    Don’t rotate them in FC.
    Rafael
  • Martin Curtis
    August 20, 2010 at 10:13 am
    Are you importing the stills directly from the camera into FCP or from files on your HDD? What do they look like in, say, Preview?
  • David Burkart
    August 20, 2010 at 3:04 pm
    Nope, camera -> HDD -> FCP. And in Preview they’re aligned correctly…
