Activity › Forums › Apple Final Cut Pro › FCP7 to FCPX
Eric Santiago
July 15, 2022 at 11:07 pmI would say yes but with older Premiere versions.
Haven’t seen this tested with anything in the last 5 years.
Andrew Rozendal
March 11, 2025 at 7:26 pmHi Doug, are you still able to do a FCP7 XML export? I have a .fcp that I need to import into FCPX but I don’t have a copy of FCP7 to be able to use the export feature to create the XML.
Doug Metz
March 13, 2025 at 4:37 amHey Andrew!
I can and still do these conversions. Can you post the project file?
Andrew Rozendal
March 14, 2025 at 8:10 pmHi Doug,
Here it is. I so appreciate this. There are two project files in there in case one of them isn’t the one I need.
Thank you so much!
Doug Metz
March 14, 2025 at 8:54 pmHey Andrew,
I took a couple screenshots of each, saved out batch lists, converted to .fcpxml, and imported both into a new Library. Have a good look through the timeline index, tons of stuff in there.
Happy weekending!
