Activity Forums Apple Final Cut Pro Legacy FCP7 : timeline to timeline copy paste changes aspect ratio of clip
  • FCP7 : timeline to timeline copy paste changes aspect ratio of clip
    Posted by Paresh Khot on November 23, 2012 at 11:57 am
    hi all,
    i m doing a project in fcp… i have multiple timelines … all timeline settings are in same (HD) format…
    Problem : if i copy clips from one timeline to another timeline it changes itz aspect ratio….
    then i hav to change the aspect ratio of each and every clip manually from 33.33 to 0…
    OMG… i already editid my footage..
    plz help me someone…
    Paul Rhys replied 11 years ago 4 Members · 4 Replies
  • Shane Ross
    November 23, 2012 at 6:58 pm
    [paresh khot] “all timeline settings are in same (HD) format…”
    They aren’t all in the same aspect ratio I’ll bet. In what you are describing, one is 1920×1080 and another is 1440×1080.
    Once you set the distortion on one clip…copy that and paste attributes, DISTORT to the other clips.
    Shane
    Little Frog Post
  • Paresh Khot
    November 24, 2012 at 4:18 am
    wher do i exactly check the ratio settings of the timeline…
    i am checking in Easy Setup… ???
    i m that way new to this technical thing so plz guide..
  • Justin Keating
    November 24, 2012 at 1:27 pm
    Go to your sequence settings in the menu. This will show you the details of your currently displayed sequence.
    Alternatively you can see the sequence details in your project window (top left window with all sequences, media, etc.) by scrolling to the right.
    Shane’s comment above will then very quickly help you configure your footage to the desired size and ratio.
  • Paul Rhys
    August 31, 2015 at 2:37 pm
    Or just copy and paste it, highlight it, go to modify, and select conform to sequence.
