Activity › Forums › Apple Final Cut Pro Legacy › FCP7 Sudden Stutter playback after rendering
  • FCP7 Sudden Stutter playback after rendering
    Posted by Michael Saul on August 10, 2014 at 6:20 pm
    I’m editing a feature film 1920×1080 23.98 on Final cut Pro 7 (See hardware below). I’ve been editing the same file, same machine, same external drives, media and configuration for over 6 months. Suddenly I get a picture stutter which seems degenerative (gets worse with time) after rendering picture or audio (the problem is global. Other projects on other drives do exactly the same thing) I”ve re-installed FCP, tried a new user profile, repaired permissions, verified all disks, taken lots of suggestions from others and nothing seems to work. Anyone have any suggestions? I’m desperate.
    Thanks for any ideas.
    Mac Pro Early 2009
    2.66 GHz Quad Core Intel Xeon
    26mg RAM
    NIVIDIA Gforce GT 120 512 mg
    OSX 10.9.4
    Michael Saul replied 12 years, 1 month ago 2 Members · 6 Replies
  • Shane Ross
    August 11, 2014 at 3:59 am
    Codec of the footage? Sequence settings? What external drives? Connected how?
    Shane
    Little Frog Post
  • Michael Saul
    August 11, 2014 at 4:14 am
    ProRes 422 codec
    Sequence:
    1920 x 1080 aspect HDTV 1080i
    Square aspect ratio
    Compressor Apple ProRes 422
    4 External Drives via firewire 800
  • Shane Ross
    August 11, 2014 at 7:01 am
    How full are those drives? For maximum speed, you need to make sure that the drives have 20% space empty. Meaning only 80% full. For a 1TB drive, that means 800GB of material on it only. Any more than that and the drives slow down.
    Shane
    Little Frog Post
  • Michael Saul
    August 11, 2014 at 3:11 pm
    Each of the drives has plenty of space. Once again though, it doesn’t matter what project I open on what drive, I get the same result.
  • Shane Ross
    August 11, 2014 at 4:39 pm
    Did you trash preferences?
    Shane
    Little Frog Post
  • Michael Saul
    August 11, 2014 at 4:51 pm
    Yes, that was the first thing I did.
