Activity Forums Apple Final Cut Pro Legacy FCP7, Snow Leopard, 444 material, and a SAN
  • FCP7, Snow Leopard, 444 material, and a SAN
    Posted by John-michael Trojan on February 22, 2011 at 12:25 am
    Since upgrading to snow leopard with FCP7 I have a terrible time playing ProRes4444 material.
    After a clean re-start I can bring the footage into FCP and play once or twice. But, after a bit, I get a spinning wheel and I the network traffic drops to almost nothing. Shortly after that something seems to “catch up” and the file plays. (in the meantime FCP is red with a not responding note in activity monitor) I’m lead to believe it has to to with meta-data, not the media.
    I am getting more than enough speed from the SAN (fiber connected), so I know that is not the problem. Once the file plays, sustained real-time is fine.
    I can also hop out of FCP and open the same file from the same location in QT and get immediate playback.
    I also don’t seem to be able to initiate the problem with 422 footage, but once it starts on the 444 footage the problem happens with 422 and everything else down the line.
    I have found a little luck turning both spotlight and MDS off, and it has seemed to help but not alleviate the problem.
    below is a diagnostic report from the time of the crash…
    any help is very appreciated. Been banging my head on this one for too long now.
    thanks so much for any suggestions!
    John-Michael Trojan
    Date/Time: 2011-02-21 19:07:55 -0500
    OS Version: 10.6.6 (Build 10J567)
    Architecture: x86_64
    Report Version: 7
    Command: Final Cut Pro
    Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Version: 7.0.3 (7.0.3)
    Build Version: 8
    Project Name: FCPApp
    Source Version: 1008261348
    Parent: launchd [116]
    PID: 768
    Event: hang
    Duration: 5.03s (sampling started after 2 seconds)
    Steps: 10 (100ms sampling interval)
    Pageins: 0
    Pageouts: 0
    Process: Final Cut Pro [768]
    UID: 503
    Thread eec1000 DispatchQueue 100
    User stack:
    10 start + 41 (in Final Cut Pro) [0x2c89]
    10 _start + 209 (in Final Cut Pro) [0x2d5b]
    10 main + 54 (in Final Cut Pro) [0x2c1278]
    10 KGMainEvent(void*) + 51 (in Final Cut Pro) [0x1539d1]
    10 RunApplicationEventLoop + 243 (in HIToolbox) [0x94d15e63]
    10 ToolboxEventDispatcher + 86 (in HIToolbox) [0x94d15d2b]
    10 SendEventToEventTarget + 52 (in HIToolbox) [0x94b8ca07]
    10 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411 (in HIToolbox) [0x94b6a196]
    10 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672 (in HIToolbox) [0x94b6b320]
    10 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1257 (in HIToolbox) [0x94b9e543]
    10 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567 (in HIToolbox) [0x94b6aecf]
    10 Events(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 67 (in Final Cut Pro) [0x414501]
    10 DoEvent(OpaqueEventRef*, KGDictInt*) + 729 (in Final Cut Pro) [0x157e4d]
    10 HandleMouseDown(OpaqueEventRef*) + 3853 (in Final Cut Pro) [0x15792b]
    10 pKGSendWindowMessage(KGWindowRec*, long, long, KGDictInt*) + 91 (in Final Cut Pro) [0x2bd5a3]
    10 pKGPanelWindowProc(long, long, KGDictInt*, void*) + 53 (in Final Cut Pro) [0x2a7781]
    10 ViewerMessageProc(long, long, KGDictInt*, KGPanelRecord*) + 222 (in Final Cut Pro) [0x25feee]
    10 ServicesPanelsMessageProc(long, long, KGDictInt*, KGPanelRecord*) + 120 (in Final Cut Pro) [0x25e872]
    10 pKGPanelMessage(long, long, KGDictInt*, KGViewRecord*) + 146 (in Final Cut Pro) [0x2b133c]
    10 PPassMouseEvent(KGPanelRecord*, KGDictInt*, long) + 1537 (in Final Cut Pro) [0x2a8031]
    10 pKGMetalPlayButtonMsg(long, long, KGDictInt*, KGViewRecord*) + 450 (in Final Cut Pro) [0x2968f0]
    10 pKGTransportButtonMessage(long, long, KGDictInt*, KGViewRecord*) + 796 (in Final Cut Pro) [0x296708]
    10 pKGTransportButtonMessage(long, long, KGDictInt*, KGViewRecord*) + 110 (in Final Cut Pro) [0x29645a]
    10 pKGViewMessage(long, long, KGDictInt*, KGViewRecord*) + 25626 (in Final Cut Pro) [0x2b0d26]
    10 pKGMetalWrapperMsg(long, long, KGDictInt*, KGViewRecord*) + 85 (in Final Cut Pro) [0x2982b9]
    10 PluginStart + 13067 (in Movie Viewer) [0x1431753b]
    10 PluginStart + 8719 (in Movie Viewer) [0x1431643f]
    10 pKGClipDefaultMessage(long, long, KGDictInt*, KGDictInt*, long) + 1012 (in Final Cut Pro) [0x1d7290]
    10 pKGPlayerHandleDefaultMenu(KGPlayerRec*, long, unsigned long) + 2589 (in Final Cut Pro) [0x1cfa5b]
    10 pKGPlayerHandleDefaultMenu(KGPlayerRec*, long, unsigned long) + 1492 (in Final Cut Pro) [0x1cf612]
    10 pKGPlayerPlayToWithRender(KGPlayerRec*, double, double, long, float, KGLoopStyle, unsigned long) + 3379 (in Final Cut Pro) [0x1d124f]
    10 pKGSetLowOSOverHeadOn() + 97 (in Final Cut Pro) [0x150563]
    10 sync + 10 (in libSystem.B.dylib) [0x9195f48a]
    Kernel stack:
    10 lo_unix_scall + 280 [0x2a0ef8]
    10 unix_syscall + 579 [0x4f1053]
    10 sync + 34 [0x2eea3b]
    10 vfs_iterate + 204 [0x2e174d]
    10 getxattr + 671 [0x2e5385]
    10 com.apple.filesystems.acfs 412.3 + 120208 [0x12df590]
    10 com.apple.filesystems.acfs 412.3 + 599708 [0x135469c]
    10 com.apple.filesystems.acfs 412.3 + 744867 [0x1377da3]
    10 lck_mtx_sleep_deadline + 104 [0x221403]
    10 thread_block + 33 [0x2272e7]
    10 thread_block_reason + 331 [0x227259]
    10 thread_dispatch + 1966 [0x226fba]
    10 machine_switch_context + 753 [0x2a8a6e]
    Thread faff7a8 DispatchQueue 83951617
    User stack:
    10 thread_start + 34 (in libSystem.B.dylib) [0x918f66e2]
    10 _pthread_start + 345 (in libSystem.B.dylib) [0x918f685d]
    10 Thread::RunHelper(void*) + 20 (in Final Cut Pro) [0x46b49a]
    10 WorkUnitPerformer::Run() + 55 (in Final Cut Pro) [0x4e67c3]
    10 Synchronizable::Wait() + 53 (in Final Cut Pro) [0x43f42b]
    10 pthread_cond_wait + 48 (in libSystem.B.dylib) [0x9193f46f]
    10 semaphore_wait_signal_trap + 10 (in libSystem.B.dylib) [0x918c9142]
    Kernel stack:
    10 semaphore_wait_continue + 0 [0x22a3dd]
    Thread d7f33d4
    User stack:
    10 IcpDecompressorComponentDispatch + 1771 (in AppleProResCodec) [0x1614740b]
    Kernel stack:
    Thread df61000
    User stack:
    Kernel stack:
    Thread e53d000
    User stack:
    10 CAPThread::Entry(CAPThread*) + 96 (in CoreMediaIOServicesPrivate) [0x10e881c]
    10 MIO::DAL::RunLoop::OwnThread(void*) + 157 (in CoreMediaIOServicesPrivate) [0x10e69ab]
    10 CFRunLoopRunInMode + 97 (in CoreFoundation) [0x93f0b291]
    10 CFRunLoopRunSpecific + 452 (in CoreFoundation) [0x93f0b464]
    10 __CFRunLoopRun + 2079 (in CoreFoundation) [0x93f0c37f]
    10 mach_msg_trap + 10 (in libSystem.B.dylib) [0x918c90fa]
    Kernel stack:
    10 ipc_mqueue_receive_continue + 0 [0x210ce6]
    Thread e5443d4
    User stack:
    Kernel stack:
    Thread e54b7a8
    User stack:
    10 threadProc(void*) + 17 (in AECore) [0x1f517fb9]
    10 select$DARWIN_EXTSN + 10 (in libSystem.B.dylib) [0x918e80c6]
    Kernel stack:
    10 sleep + 52 [0x48a3f9]
    Thread e560000
    User stack:
    Kernel stack:
    Thread e560b7c
    User stack:
    Kernel stack:
    Thread ec8cb7c
    User stack:
    Kernel stack:
    Thread ece83d4
    User stack:
    Kernel stack:
    Thread ef2e3d4
    User stack:
    10 PrivateMPEntryPoint + 68 (in CarbonCore) [0x9805885a]
    10 TSystemNotificationTask::SystemNotificationTaskProc(void*) + 643 (in DesktopServicesPriv) [0x94fbae51]
    10 CFRunLoopRun + 84 (in CoreFoundation) [0x93f113a4]
    Kernel stack:
    Thread f0393d4
    User stack:
    10 AIOFileThread(void*) + 1127 (in CarbonCore) [0x980d3732]
    10 TSWaitOnSemaphoreCommon + 511 (in CarbonCore) [0x98078c0b]
    10 TSWaitOnConditionTimedRelative + 242 (in CarbonCore) [0x98078ecd]
    10 pthread_cond_timedwait_relative_np + 47 (in libSystem.B.dylib) [0x91925ac8]
    10 semaphore_timedwait_signal_trap + 10 (in libSystem.B.dylib) [0x918c915a]
    Kernel stack:
    Thread f1ff7a8
    User stack:
    Kernel stack:
    Thread f760b7c
    User stack:
    10 start_wqthread + 30 (in libSystem.B.dylib) [0x918eebc6]
    10 __workq_kernreturn + 10 (in libSystem.B.dylib) [0x918eea12]
    Kernel stack:
    10 bsdthread_create + 1313 [0x4cd603]
    Thread f762b7c
    User stack:
    Kernel stack:
    Thread faedb7c
    User stack:
    Kernel stack:
    Thread fafc7a8
    User stack:
    Kernel stack:
    Thread ffea3d4
    User stack:
    Kernel stack:
    Thread ffea7a8
    User stack:
    Kernel stack:
    Thread ffeab7c
    User stack:
    10 ReadSchedulerThreadEntryPoint + 4698 (in QuickTimeComponents) [0x96891dc9]
    Kernel stack:
    Thread 10075000
    User stack:
    Kernel stack:
    Thread 10075b7c
    User stack:
    Kernel stack:
    Thread 1030db7c
    User stack:
    Kernel stack:
    Thread 103bc3d4
    User stack:
    Kernel stack:
    Thread 103bcb7c
    User stack:
    Kernel stack:
    Thread 16e66000
    User stack:
    Kernel stack:
    Thread 16e667a8
    User stack:
    Kernel stack:
    Thread 16eb77a8
    User stack:
    Kernel stack:
    Thread 22e21b7c
    User stack:
    Kernel stack:
    Thread 22e223d4
    User stack:
    10 DisplayQueue::Run() + 681 (in Final Cut Pro) [0x42911f]
    Kernel stack:
    Thread 22e22b7c
    User stack:
    10 _pthread_wqthread + 390 (in libSystem.B.dylib) [0x918eed81]
    10 _dispatch_worker_thread2 + 240 (in libSystem.B.dylib) [0x918ef2fe]
    10 _dispatch_queue_invoke + 163 (in libSystem.B.dylib) [0x918ef559]
    10 kevent + 10 (in libSystem.B.dylib) [0x918ef982]
    Kernel stack:
    10 kevent + 97 [0x473932]
    Thread 22e283d4
    User stack:
    Kernel stack:
    Thread 22e2b3d4
    User stack:
    10 aecore::CThread::runThread() + 34 (in AECore) [0x1f51a022]
    10 swamp::CRAdReceiver2::ReceivingThread::runOnce() + 234 (in DistributedObjects) [0x1f321460]
    Kernel stack:
    Thread 22e2c3d4
    User stack:
    Kernel stack:
    Binary Images:
    0x1000 – 0x870ffc com.apple.FinalCutPro 7.0.3 (7.0.3) <41B8A263-80F3-BCC3-FE28-82DE571687A1> /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    0x10d9000 – 0x1113ffb com.apple.CoreMediaIOServicesPrivate 34.0 (1360) <8F44EB7A-C722-55D2-AF12-838553442BEE> /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Versions/A/CoreMediaIOServicesPrivate
    0x14313000 – 0x14329ffb com.apple.FinalCutPro.Plugins.Movie Viewer 7.0.3 (7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Viewer.bundle/Contents/MacOS/Movie Viewer
    0x1613d000 – 0x161aafe7 com.apple.AppleProResCodec 2.0 (224) /Library/QuickTime/AppleProResCodec.component/Contents/MacOS/AppleProResCodec
    0x1f30e000 – 0x1f382ff8 com.apple.qmaster.do 3.5.3 (3.5.3) <4CE7B752-D141-5B9D-6248-8A6A6E0240F9> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/DistributedObjects.framework/Versions/A/DistributedObjects
    0x1f500000 – 0x1f65aff7 com.apple.AECore 3.5.3 (3.5.3) <2BAD733C-D2F3-F9FD-C5CD-22C23820EE15> /Library/Frameworks/AECore.framework/Versions/A/AECore
    0x918c8000 – 0x91a6fff7 libSystem.B.dylib ??? (???) <4FFBF71A-D603-3C64-2BC6-BFBFFFD562F0> /usr/lib/libSystem.B.dylib
    0x93ecf000 – 0x9404afe7 com.apple.CoreFoundation 6.6.4 (550.42) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x94b63000 – 0x94e87fef com.apple.HIToolbox 1.6.4 (???) <4699C8BB-DE74-C530-564B-D131F74C9B54> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x94fb9000 – 0x95094feb com.apple.DesktopServices 1.5.9 (1.5.9) /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x962d9000 – 0x9722bfef com.apple.QuickTimeComponents.component 7.6.6 (1756) <00010203-0405-0607-0809-0A0B0C0D0E0F> /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
    0x98032000 – 0x98352ff3 com.apple.CoreServices.CarbonCore 861.23 (861.23) <96534EF7-C22E-0C01-C56F-FF7047E41224> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    Process: AirPort Base Station Agent [142]
    Path: /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent
    UID: 503
    Thread f56f7a8 DispatchQueue 1
    User stack:
    10 ??? (in AirPort Base Station Agent + 5692) [0x10000163c]
    10 NSApplicationMain + 364 (in AppKit) [0x7fff87a441a8]
    10 -[NSApplication run] + 395 (in AppKit) [0x7fff87a4b48b]
    10 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 155 (in AppKit) [0x7fff87a857a9]
    10 _DPSNextEvent + 718 (in AppKit) [0x7fff87a85e64]
    10 BlockUntilNextEventMatchingListInMode + 59 (in HIToolbox) [0x7fff854fa5f8]
    10 ReceiveNextEventCommon + 310 (in HIToolbox) [0x7fff854fa73f]
    10 RunCurrentEventLoopInMode + 333 (in HIToolbox) [0x7fff854fa93a]
    10 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x7fff8489fdbf]
    10 __CFRunLoopRun + 1698 (in CoreFoundation) [0x7fff848a0932]
    10 mach_msg_trap + 10 (in libSystem.B.dylib) [0x7fff84d262da]
    Kernel stack:
    Thread f5c4000 DispatchQueue 2
    User stack:
    10 start_wqthread + 13 (in libSystem.B.dylib) [0x7fff84d40005]
    10 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x7fff84d40168]
    10 _dispatch_worker_thread2 + 252 (in libSystem.B.dylib) [0x7fff84d4083e]
    10 _dispatch_queue_invoke + 185 (in libSystem.B.dylib) [0x7fff84d40d14]
    10 kevent + 10 (in libSystem.B.dylib) [0x7fff84d3f16a]
    Kernel stack:
    Thread f6627a8
    User stack:
    10 thread_start + 13 (in libSystem.B.dylib) [0x7fff84d5f3e9]
    10 _pthread_start + 331 (in libSystem.B.dylib) [0x7fff84d5f536]
    10 select$DARWIN_EXTSN + 10 (in libSystem.B.dylib) [0x7fff84d69e92]
    Kernel stack:
    Binary Images:
    0x100000000 – 0x100027fff com.apple.AirPortBaseStationAgent 1.5.5 (155.2) <00010203-0405-0607-0809-0A0B0C0D0E0F> /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent
    0x7fff84854000 – 0x7fff849cbfe7 com.apple.CoreFoundation 6.6.4 (550.42) <770C572A-CF70-168F-F43C-242B9114FCB5> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff84d25000 – 0x7fff84ee6fff libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
    0x7fff854cc000 – 0x7fff857cafe7 com.apple.HIToolbox 1.6.4 (???) <263AD497-F4CC-9610-E7D3-B95CF6F02030> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fff87a42000 – 0x7fff88438fff com.apple.AppKit 6.6.7 (1038.35) <9F4DF818-9DB9-98DA-490C-EF29EA757A97> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    Process: AppleSpell [739]
    Path: /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
    UID: 503
    Thread f65a3d4 DispatchQueue 1
    User stack:
    10 ??? (in AppleSpell + 4816) [0x1000012d0]
    10 ??? (in AppleSpell + 5472) [0x100001560]
    10 -[NSSpellServer run] + 72 (in Foundation) [0x7fff8183d00e]
    10 CFRunLoopRun + 70 (in CoreFoundation) [0x7fff8489fb46]
    Kernel stack:
    Thread 22e8d3d4
    User stack:
    Kernel stack:
    Binary Images:
    0x100000000 – 0x1000a9fe7 com.apple.AppleSpell 1.6.2 (62.2) /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
    0x7fff817be000 – 0x7fff81a41ff7 com.apple.Foundation 6.6.4 (751.42) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    Process: AppleVNCServer [149]
    Path: /System/Library/CoreServices/RemoteManagement/AppleVNCServer.bundle/Contents/MacOS/AppleVNCServer
    UID: 503
    Thread f6e97a8 DispatchQueue 1
    User stack:
    10 ??? (in AppleVNCServer + 5220) [0x100001464]
    10 ??? (in AppleVNCServer + 6677) [0x100001a15]
    10 ??? (in AppleVNCServer + 19068) [0x100004a7c]
    Kernel stack:
    Thread f6e93d4 DispatchQueue 2
    User stack:
    Kernel stack:
    Thread f6f37a8
    User stack:
    10 PrivateMPEntryPoint + 63 (in CarbonCore) [0x7fff849f6411]
    Kernel stack:
    Thread f6f3b7c
    User stack:
    Kernel stack:
    Binary Images:
    0x100000000 – 0x100050fe7 com.apple.AppleVNCServer 3.4 (3.4) <9BD43783-6C30-A382-E3B9-B307FB207F05> /System/Library/CoreServices/RemoteManagement/AppleVNCServer.bundle/Contents/MacOS/AppleVNCServer
    0x7fff849ef000 – 0x7fff84d23fff com.apple.CoreServices.CarbonCore 861.23 (861.23) <96465459-6536-3FD7-7504-B59D0390EEC5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    Process: ARDAgent [137]
    Path: /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/MacOS/ARDAgent
    UID: 503
    Thread f560b7c DispatchQueue 1
    User stack:
    10 ??? (in ARDAgent + 4716) [0x10000126c]
    10 ??? (in ARDAgent + 5087) [0x1000013df]
    Kernel stack:
    Thread f5bfb7c DispatchQueue 2
    User stack:
    Kernel stack:
    Thread f560000
    User stack:
    10 recvfrom + 10 (in libSystem.B.dylib) [0x7fff84d69eb6]
    Kernel stack:
    10 lo64_unix_scall + 77 [0x2a143d]
    10 unix_syscall64 + 617 [0x4f13be]
    10 recvfrom_nocancel + 325 [0x4b81b9]
    10 shutdown + 501 [0x4b7a13]
    10 soreceive + 1134 [0x4b275e]
    10 sbwait + 150 [0x4b485c]
    10 msleep + 157 [0x48a73c]
    10 wakeup + 334 [0x48a049]
    10 lck_mtx_sleep + 87 [0x221a0b]
    Thread f5603d4
    User stack:
    Kernel stack:
    Thread f6e9b7c
    User stack:
    10 __wait4 + 10 (in libSystem.B.dylib) [0x7fff84d74652]
    Kernel stack:
    Binary Images:
    0x100000000 – 0x1000d2fff com.apple.RemoteDesktopAgent 3.4 (3.4) <0F55E933-57F2-2D05-F2F0-DD8550291426> /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/MacOS/ARDAgent
    Process: autofsd [47]
    Path: /usr/libexec/autofsd
    UID: 0
    Thread e544b7c DispatchQueue 1
    User stack:
    10 ??? (in autofsd + 5340) [0x1000014dc]
    10 ??? (in autofsd + 6461) [0x10000193d]
    Kernel stack:
    Thread e565b7c DispatchQueue 2
    User stack:
    Kernel stack:
    Binary Images:
    0x100000000 – 0x100001ff7 autofsd ??? (???) <81B94E6C-3DDE-56E9-BABB-9AFA7883ECCD> /usr/libexec/autofsd
    Process: blued [16]
    Path: /usr/sbin/blued
    UID: 0
    Thread d8593d4 DispatchQueue 1
    User stack:
    10 ??? (in blued + 5564) [0x1000015bc]
    10 ??? (in blued + 151747) [0x1000250c3]
    10 -[NSRunLoop(NSRunLoop) run] + 77 (in Foundation) [0x7fff818097c3]
    10 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 270 (in Foundation) [0x7fff818098e4]
    Kernel stack:
    Thread df613d4 DispatchQueue 2
    User stack:
    Kernel stack:
    Binary Images:
    0x100000000 – 0x100046fe7 blued ??? (???) /usr/sbin/blued
    Process: compressord [672]
    Path: /Library/Frameworks/Compressor.framework/Resources/CompressorTranscoderX.bundle/Contents/MacOS/compressord
    UID: 0
    Process: compressord [788]
    Path: /Library/Frameworks/Compressor.framework/Resources/CompressorTranscoder.bundle/Contents/MacOS/compressord
    UID: 503
    Process: configd [14]
    Path: /usr/libexec/configd
    UID: 0
    Thread d7d83d4 DispatchQueue 1
    User stack:
    10 start + 52 (in configd) [0x100000cf0]
    10 main + 2051 (in configd) [0x100001506]
    10 server_loop + 72 (in configd) [0x100001d5c]
    Kernel stack:
    Thread d7f9000 DispatchQueue 2
    User stack:
    Kernel stack:
    Thread d72a000
    User stack:
    10 _io_pm_force_active_settings + 2271 (in PowerManagement) [0x1000ac3c5]
    Kernel stack:
    Thread d72f3d4
    User stack:
    10 plugin_exec + 1440 (in configd) [0x1000034c3]
    Kernel stack:
    Thread d859000
    User stack:
    Kernel stack:
    Thread df623d4
    User stack:
    10 pppcntl_run_thread + 1595 (in PPPController) [0x10071890d]
    Kernel stack:
    Thread 22f70b7c
    User stack:
    10 __workq_kernreturn + 10 (in libSystem.B.dylib) [0x7fff84d3ff8a]
    Kernel stack:
    Binary Images:
    0x100000000 – 0x100026ff7 configd ??? (???) <655B1B55-1602-6EE5-01AA-61F29C4145F5> /usr/libexec/configd
    0x1000a9000 – 0x1000baff7 com.apple.SystemConfiguration.PowerManagement 160.0.0 (160.0.0) <9A8C56CC-DDE2-CF11-538A-009A9EB760C8> /System/Library/SystemConfiguration/PowerManagement.bundle/Contents/MacOS/PowerManagement
    0x100706000 – 0x10072ffff com.apple.SystemConfiguration.PPPController 1.5 (1.5) <084E2BC2-19D0-72D4-E1B5-F7B720362190> /System/Library/SystemConfiguration/PPPController.bundle/Contents/MacOS/PPPController
    Process: coreaudiod [97]
    Path: /usr/sbin/coreaudiod
    UID: 202
    Thread ef407a8 DispatchQueue 1
    User stack:
    10 ??? (in coreaudiod + 6508) [0x10000196c]
    10 ??? (in coreaudiod + 29864) [0x1000074a8]
    Kernel stack:
    Thread ef67000 DispatchQueue 2
    User stack:
    Kernel stack:
    Thread eff23d4
    User stack:
    10 CAPThread::Entry(CAPThread*) + 125 (in CoreAudio) [0x7fff81373745]
    10 HALRunLoop::OwnThread(void*) + 152 (in CoreAudio) [0x7fff81386776]
    Kernel stack:
    Thread 22f6fb7c
    User stack:
    Kernel stack:
    Binary Images:
    0x100000000 – 0x100020fe7 coreaudiod ??? (???) /usr/sbin/coreaudiod
    0x7fff81355000 – 0x7fff813d4fe7 com.apple.audio.CoreAudio 3.2.6 (3.2.6) <6D8AD3F7-409D-512C-C5BE-66C64D1B8F3E> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    Process: coreservicesd [53]
    Path: /System/Library/CoreServices/coreservicesd
    UID: 0
    Thread e565000
    User stack:
    10 ??? (in coreservicesd + 3756) [0x100000eac]
    10 _CoreServicesServerMain + 522 (in CarbonCore) [0x7fff84a9fae2]
    Kernel stack:
    Thread e5437a8 DispatchQueue 2
    User stack:
    Kernel stack:
    Thread d7077a8
    User stack:
    10 read + 10 (in libSystem.B.dylib) [0x7fff84d309c6]
    Kernel stack:
    10 read_nocancel + 158 [0x498faa]
    10 write + 312 [0x49882e]
    10 get_pathbuff + 3054 [0x306b6c]
    10 tsleep + 105 [0x48a634]
    10 wakeup + 786 [0x48a20d]
    Thread e0847a8
    User stack:
    10 fmodWatchConsumer + 347 (in CarbonCore) [0x7fff84a537a6]
    10 __semwait_signal + 10 (in libSystem.B.dylib) [0x7fff84d60fca]
    Kernel stack:
    Thread f6c5b7c
    User stack:
    Kernel stack:
    9 bsdthread_create + 1313 [0x4cd603]
    1 lo64_unix_scall + 77 [0x2a143d]
    1 unix_syscall64 + 617 [0x4f13be]
    1 workq_kernreturn + 1025 [0x4ce305]
    1 proc_settargetconc + 4896 [0x4ccee8]
    1 thread_block + 33 [0x2272e7]
    1 thread_block_reason + 309 [0x227243]
    1 thread_go + 1961 [0x22661f]
    1 thread_setrun + 1360 [0x22584d]
    1 machine_idle + 239 [0x2abb88]
    Binary Images:
    0x100000000 – 0x100000fff coreservicesd ??? (???) /System/Library/CoreServices/coreservicesd
    Process: cupsd [760]
    Path: /usr/sbin/cupsd
    UID: 0
    Thread ffdd7a8
    User stack:
    10 ??? (in cupsd + 4504) [0x175aef198]
    10 ??? (in cupsd + 109891) [0x175b08d43]
    Kernel stack:
    Thread 22e217a8 DispatchQueue 2
    User stack:
    Kernel stack:
    Thread 103efb7c
    User stack:
    Kernel stack:
    Thread 22e28b7c
    User stack:
    10 ??? (in cupsd + 277689) [0x175b31cb9]
    Kernel stack:
    Binary Images:
    0x175aee000 – 0x175b49ff7 cupsd ??? (???) <09F44E55-81E3-CB4D-3176-4906687B243E> /usr/sbin/cupsd
    Process: cvmsComp_i386 [790]
    Path: /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/cvmsComp_i386
    UID: 503
    Thread 103bc7a8
    User stack:
    10 ??? (in cvmsComp_i386 + 4969) [0x2369]
    10 llvm::CVMSMemoryManager::getDlsymTable() const + 4112 (in cvmsComp_i386) [0x52b6]
    10 mach_msg_server + 610 (in libSystem.B.dylib) [0x919350e2]
    10 mach_msg_overwrite_trap + 10 (in libSystem.B.dylib) [0x918c9106]
    Kernel stack:
    Binary Images:
    0x1000 – 0x6ffb cvmsComp_i386 ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/cvmsComp_i386
    Process: cvmsServ [84]
    Path: /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/cvmsServ
    UID: 0
    Thread e55c000 DispatchQueue 1
    User stack:
    10 ??? (in cvmsServ + 4100) [0x100001004]
    10 ??? (in cvmsServ + 23081) [0x100005a29]
    10 mach_msg_server + 539 (in libSystem.B.dylib) [0x7fff84da2eda]
    10 mach_msg_overwrite_trap + 10 (in libSystem.B.dylib) [0x7fff84d262e6]
    Kernel stack:
    Thread f5513d4
    User stack:
    10 ??? (in cvmsServ + 16132) [0x100003f04]
    Kernel stack:
    Binary Images:
    0x100000000 – 0x100008fff cvmsServ ??? (???) <2B92B368-C9A8-173F-AB83-97E8026631E0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/cvmsServ
    Process: DirectoryService [11]
    Path: /usr/sbin/DirectoryService
    UID: 0
    Thread d8043d4 DispatchQueue 1
    User stack:
    10 start + 52 (in DirectoryService) [0x10000cfec]
    10 main + 3061 (in DirectoryService) [0x10000dbe9]
    Kernel stack:
    Thread d7dd000 DispatchQueue 2
    User stack:
    Kernel stack:
    Thread d7d4000 DispatchQueue 8
    User stack:
    10 _dispatch_worker_thread2 + 239 (in libSystem.B.dylib) [0x7fff84d40831]
    10 _dispatch_call_block_and_release + 15 (in libSystem.B.dylib) [0x7fff84d622c4]
    10 ____StartKernelListener_block_invoke_8 + 33 (in DirectoryService) [0x1000286bd]
    10 semaphore_wait_trap + 10 (in libSystem.B.dylib) [0x7fff84d26316]
    Kernel stack:
    Thread d7e17a8 DispatchQueue 8
    User stack:
    10 syscall + 10 (in libSystem.B.dylib) [0x7fff84d628c2]
    Kernel stack:
    Thread d7e1b7c
    User stack:
    10 DSLThread::_RunWrapper(void*) + 67 (in DirectoryServiceCore) [0x10017934b]
    10 DSCThread::Run() + 36 (in DirectoryServiceCore) [0x1001790ac]
    10 CPluginRunLoopThread::ThreadMain() + 150 (in DirectoryService) [0x10001c784]
    Kernel stack:
    Thread df617a8
    User stack:
    Kernel stack:
    Thread 22f767a8
    User stack:
    Kernel stack:
    10 bsdthread_create + 1477 [0x4cd6a7]
    Binary Images:
    0x100000000 – 0x100120ff7 DirectoryService ??? (???) <47EEEB29-8CD0-1429-A387-1458A0923FC7> /usr/sbin/DirectoryService
    0x100171000 – 0x100182fff com.apple.DirectoryServiceCore.Framework 3.6 (621.9) <40AB5630-8B99-DA0A-9671-1D72073EC242> /System/Library/PrivateFrameworks/DirectoryServiceCore.framework/Versions/A/DirectoryServiceCore
    Process: diskarbitrationd [13]
    Path: /usr/sbin/diskarbitrationd
    UID: 0
    Thread d7347a8 DispatchQueue 1
    User stack:
    10 ??? (in diskarbitrationd + 4064) [0x100000fe0]
    10 ??? (in diskarbitrationd + 32876) [0x10000806c]
    Kernel stack:
    Thread d7f9b7c DispatchQueue 2
    User stack:
    Kernel stack:
    Binary Images:
    0x100000000 – 0x10001bfef diskarbitrationd ??? (???) /usr/sbin/diskarbitrationd
    Process: diskimages-helper [357]
    Path: /System/Library/PrivateFrameworks/DiskImages.framework/Resources/diskimages-helper
    UID: 503
    Thread f6c5000 DispatchQueue 1
    User stack:
    10 ??? (in diskimages-helper + 16608) [0x1000040e0]
    10 ??? (in diskimages-helper + 17293) [0x10000438d]
    Kernel stack:
    Thread fafcb7c DispatchQueue 2
    User stack:
    Kernel stack:
    Thread f65ab7c
    User stack:
    10 __NSThread__main__ + 1429 (in Foundation) [0x7fff817cf0a5]
    10 ??? (in diskimages-helper + 40146) [0x100009cd2]
    10 ??? (in diskimages-helper + 42898) [0x10000a792]
    10 DI_kextDriveGetRequest + 41 (in DiskImages) [0x7fff88d81d6f]
    10 IOConnectCallStructMethod + 50 (in IOKit) [0x7fff80af53ab]
    10 IOConnectCallMethod + 325 (in IOKit) [0x7fff80af5328]
    10 io_connect_method + 490 (in IOKit) [0x7fff80b38ad2]
    Kernel stack:
    10 lo64_mach_scall + 77 [0x2a148d]
    10 thread_setuserstack + 405 [0x295156]
    10 mach_msg_overwrite_trap + 274 [0x216c9d]
    10 ipc_kmsg_send + 111 [0x210a3a]
    10 ipc_kobject_server + 244 [0x21d8ba]
    10 iokit_server_routine + 4669 [0x285bce]
    10 is_io_connect_method + 467 [0x566bdb]
    10 IOUserClient::externalMethod(unsigned int, IOExternalMethodArguments*, IOExternalMethodDispatch*, OSObject*, void*) + 960 [0x56635a]
    10 shim_io_connect_method_structureI_structureO + 350 [0x565218]
    10 com.apple.driver.DiskImages 289 + 11873 [0x1270e61]
    10 com.apple.driver.DiskImages 289 + 6846 [0x126fabe]
    10 semaphore_wait + 58 [0x22aa1a]
    10 semaphore_destroy + 703 [0x22a724]
    John-michael Trojan replied 15 years, 7 months ago 5 Members · 6 Replies
  • Bob Zelin
    February 22, 2011 at 3:11 am
    I am shocked at your post, as we have just had issues with my crappy little SAN (Final Share) with ProRes422HQ multiple streams, and to our shock, found out that we can do MORE STREAMS with ProRes4444 than we can do with ProRes422HQ.
    SO, I must ask you – what brand of SAN system are you using, because even a 4 Gig fibre SAN should blow the doors off of an ethernet system !
    I can only assure you of one thing – this is not an OS-X 10.6 problem. But you must tell me what SAN (or SAN management software, drive array, and switch) are you using) – and you should be posting this quesiton on the SAN networks forum.
    Bob Zelin
  • John-michael Trojan
    February 22, 2011 at 3:26 am
    I agree it is definitely not the SAN playing the media.
    Thanks for the advice on the re-direct. Some down time has helped lead to a few decent thoughts as well.
  • Jon Smitherton
    February 22, 2011 at 4:06 am
    Been have trouble here with a SAN too. Check that your renders, waveforms and autosave are on a local (pref) RAID…fixed my waveforms – think it was a permissions thing.
    Worth a try anyway
    Jon
  • Shane Ross
    February 22, 2011 at 4:10 am
    Using the CRASH REPORTER from digitalrebellion.com…
    Corrupt / Unsupported Media
    This crash was caused by corrupt media or media that is unsupported by Final Cut Pro. A common cause of this crash is using media on your timeline that is unsuitable for editing such as AVI, WMV or MPEG-derived codecs (XDCAM, HDV, MPEG-2, H.264).
    Suggested Actions
    Use Corrupt Clip Finder to locate the problematic clip and then recapture or attempt to repair it.
    If your sequence codec is set to an MPEG-based codec such as MPEG-2, HDV, XDCAM or H.264, change it to ProRes.
    Alternatively, and for best results, convert any MPEG-based media to ProRes.
    If the issue is related to a codec, upgrade the codec if an upgrade is available or consider transcoding your footage to an editing-friendly codec such as ProRes.
    If you are using CMYK images, convert them to RGB.
    Relevant Line
    Shane
  • Jon Chappell
    February 22, 2011 at 4:02 pm
    This is a hang, not a crash. Crash Analyzer doesn’t support hangs so take whatever it says with a grain of salt 🙂
    My software:
    FCS Maintenance Pack – Tools to keep Final Cut Studio running smoothly and fix problems when they arise
    FCP Versioner – Backs up Final Cut Pro projects to XML and creates changelists for each revision
    More tools…
    February 22, 2011 at 6:43 pm
    Thanks for the help all.
    You are correct that there is nothing really wrong with the media (it already is ProRes and plays down fine in another room).
    I have tried putting the cache files on local storage but not the boot drive. After disconnecting the fiber for a start-up and reconnecting (effectively clearing any outstanding logs/etc and restarting the meta-data controller) things will keep up for a bit; but alas – the wheel eventually comes back.
    I posted here wondering if anyone had experienced anything similar as a FCP user. However, at this point I’ll re-direct back to a potential issue with the meta-data controllers, etc.
    thanks for all the input. It is appreciated.
