Activity › Forums › Apple Final Cut Pro Legacy › FCP7 settings for 1080p and 720p in the same project
  • FCP7 settings for 1080p and 720p in the same project
    Posted by Ben Godfrey on December 1, 2010 at 1:58 am
    Hi guys
    I’m pretty new to all this stuff. I shot a bunch of video on my goproHD camera in 1080p 25fps and 720p 50fps all PAL.
    I’ve converted them in mpegstreamclip.
    1080p..
    Pro Res 422
    high quality
    unchecked deinterlace
    1980×1080(unscaled)
    what settings would work on the 720p so i could use both formats in the same project.
    Just wondering if that workflow was ok and i’m going in the right direction.
    Sorry if this has been discussed before for really mind the right answer
    Cheers
    Ben
    Rafael Amador replied 15 years, 10 months ago 3 Members · 2 Replies
  • Thomas Morter-laing
    December 1, 2010 at 10:37 am
    I recently had to do this and was told my two options (in my situation) were to either edit all in a 720p sequence, or in a 1080p sequence and allow the frame to be stretched- it depends on what your outputting for and what equipment you have at your disposal, which in my case was virtually nothing. I hope someone can answer with more authority on the subject for you 🙂
    Tom Morter-Laing
    Freelance Editor
    Certified Apple Product Proffessional, 2010
    http://www.depictproductions.co.uk
    Sony Z5, with Rode NTG2.
    iMac 27″ intel i7 2.93GHz, 12GB RAM, ATI HD5750 [1GB GDDR5], 2TB Int. SATA with 2TB External HDD; (FW800), with Elgato Turbo H264HD.
  • Rafael Amador
    December 1, 2010 at 12:49 pm
    Hi Ben,
    As long as you have no constrains on your delivery format, put everything on a 720p25 (NO p50), and edit.
    Before exporting, set “Render Motion Effects: BEST”.
    Next time, for a similar job, you can save time downscaling the 1080 stuff to 720 while you are transcoding in MPGStreamclip.
    rafael
    http://www.nagavideo.com
