FCP7: Reconnect Media Not Working!
I have reconnected media hundreds of times, but for some reason recently I am having trouble. I just got the new Mac Pro, and installed FCP7 from its original discs. Everything else works fine, but recently when I try to reconnect media to files over a network, the “locate” window shows nothing in the folder(s) I navigate to. I can navigate to these folders just fine in my finder, play the clips, everything. We have multiple computers connected via ethernet server, and all other transfers and connections are fine. I can reconnect media that is local on my internal hard drive or via thunderbolt/usb connected drives. Is there some sort of setting in Final Cut that would prevent this? Sometimes I can see the folders I want, but when I double-click into them, there’s nothing inside, and then those main destinations (networked computers, drobos, etc.) are no longer in the side bar. What gives??
Thanks in advance!
