Activity › Forums › Apple Final Cut Pro › FCP7 project transfer to FCPX ???
Posted by Martin Clark on October 14, 2011 at 2:56 pmHow can I transfer my existing FCP7 project over to FCPX…or is this not possible ??
Martin
Elias Huch replied 14 years, 9 months ago 6 Members · 8 Replies -
Craig Seeman
October 14, 2011 at 4:34 pmOnly sequence sans all effects and transitions through CatDV Pro.
Mathieu Marano
October 14, 2011 at 10:10 pmActually since this morning there is a new way. You can send a project from FCP7 to FCPX thru DaVinci Resolve…and back. Here is the video tutorial I did.
https://www.youtube.com/watch?v=DNRnH9zsP6g
Only the sound isn’t going through.
Mathieu Marano
offline/online editor – motion graphics – Post-prod director – DaVinci Resolve operator
http://www.ilovehue.netAdministrator of the Montreal Final Cut User Group
http://www.finalcutmtl.orgSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Jason Jenkins
October 14, 2011 at 10:43 pm[Mathieu Marano] “You can send a project from FCP7 to FCPX thru DaVinci Resolve…and back. Here is the video tutorial I did.”
Very cool! Will this work with Resolve Lite?
Jason Jenkins
Flowmotion Media
Video production… with style! -
Mathieu Marano
October 15, 2011 at 1:15 amCould be. Resolve Lite supports roundtripping and is now updates to V8.1 so it should be able to handle FCPX XML. I can’t test it cause I have the full version on both of my macs. But keep me posted if you try it and it works
Mathieu Marano
http://www.finalcutmtl.org -
Jason Jenkins
October 15, 2011 at 1:42 amI’m trying it out right now, but when I try to import the FCP7 xml in Resolve, it always tells me, “No clips can be found. Please add clips to the media pool and try reimporting“. I’ve pointed it to the folder where the clips reside, but no go. Not sure what I’m doing wrong.
Jason Jenkins
Flowmotion Media
Craig Seeman
October 15, 2011 at 5:18 am[Mathieu Marano] “Could be. Resolve Lite supports roundtripping and is now updates to V8.1 so it should be able to handle FCPX XML.”
A little birdie told me that would happen. And the cost for this tool would be . . . and it does a bit ‘o grading too.
Kinda explains the facial expression I got from one of the Blackmagic guys at their booth at CCW yesterday when I asked how soon and maybe lite too.
Patrice Freymond
October 16, 2011 at 1:34 pmI tried doing it through the Lite version and it works.
With a few bugs:anamorphic sd did not get flagged properly so when opening my mixed sd media sequence in FCPx, formats were a bit all over the place. Cross dissolve does get replaced but opacity adjustments do not make it through.
Titles appear as a transparent clip connected to the primary storyline. For me the fact that audio does not make it through is a deal breaker but hey, Resolve lite is for free so…
Pat
Elias Huch
December 20, 2011 at 10:09 pmIt worked with Lite for me also, but Audio did not come across. Any ideas why?
Elias Huch
Motion Graphics Designer
Reelvizion Productions
