Activity Forums Apple Final Cut Pro Legacy FCP7 General Error 34 AND Codec Error messages when trying to export.
  • FCP7 General Error 34 AND Codec Error messages when trying to export.
    Posted by Andrew louis Marnik on August 3, 2010 at 6:03 pm
    Working with ProRes 422 LT footage and Self-Contained FCP Movies. Working on a ‘best of’ episode and using the finished shows as some of the footage.
    When I try to export using quicktime converstion, I get a “Codec Error” message and when I try to export it as a self-contained final cut movie to convert in Quicktime Pro, I get a “General Error (34)” message.
    Even when I try to reload the project from the autosave vault, all files go offline.
    Please help!
    Project file is on one hard drive with 200GB available.
    Self-contained episodes are on another external hard drive with 100GB available.
    Running FCP7
    1.83 GHz Intel Core Duo
    2 GB 533 MHz DDR2 SDRAM
    Running OSX V 10.5.8
    Shari Berman replied 14 years, 4 months ago 5 Members · 6 Replies
  • Andrew louis Marnik
    August 3, 2010 at 6:16 pm
    Ok gang…. after ten minutes of having a heart attack, it was something small and I missed it completely: checking your in and out points. I figured I’d keep this up here in case anyone else has the problem or CCow can delete it if they want.
    Cheers. I can breathe again.
  • Beth Goins
    August 15, 2010 at 5:42 pm
    Oh, thank you for posting this!! You just saved me from having a stroke. 😉
  • Scott Davis
    August 17, 2010 at 3:45 pm
    Andrew, I am having a similar problem. What do you mean by checking your in and out points? Mine does it with no in out points.
    Scott Davis
    View Scott Davis's profile on LinkedIn
    August 17, 2010 at 3:49 pm
    Hey Scott,
    I had something later in my timeline that I had deleted, yet the in and out points still remained, but were not visible. I went up to the “mark” tab and hit “clear in and out,” tried exporting and it worked like a charm after that.
    Hope this helps.
  • Johann Lohrmann
    October 8, 2010 at 4:32 am
    Thank you guys so much for posting this. Never had it before and ya saved my bacon.
  • Shari Berman
    May 24, 2012 at 2:54 pm
    THANK YOU! I got that error today…didn’t realize I had set in and out points accidentally (probably hit a short cut key)…totally saved me!
