Activity Forums Apple Final Cut Pro Legacy FCP7 File “unreadable or too new”??
  • FCP7 File “unreadable or too new”??
    Posted by Brian Foote on August 1, 2011 at 3:13 pm
    So im opening a FCP7 file in FCP7 and i get the following:
    This project is unreadable or may be too new for this version of Final Cut.”
    Strange….ITS THE SAME DAMN VERSION!!
    It loads to about 46% and then i spits this message out to me.
    Anyone have some insight? The FCP file is 24mb.
    Any help would be much appreciated.
    Brian Foote
    Editorial | Motion Design
    http://www.brianfoote.tv
    Maja Zdanowski replied 12 years, 4 months ago 4 Members · 4 Replies
  • Jerry Hofmann
    August 1, 2011 at 4:31 pm
    It’s corrupt I’ll bet… got an autosave or can you get it or have it emailedl (after compressing the file first) it from somewhere?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Anders Teigen
    October 14, 2013 at 7:54 am
    I’ve had the same problem, but it is not consistent. Some times it opens, some times not. It does not seem corrupted, and it happens on different project files. I haven’t found any explanation either, so if you find something, please call out.
    Anders
    Editor
  • Anders Teigen
    October 14, 2013 at 8:00 am
  • Maja Zdanowski
    April 12, 2014 at 6:43 pm
    I’m having the same problem:
    Are you able to look at my project file? I have an older version that you can compare it to, and no I do not have an auto save version. stupid me forgot to turn it back on after working on another project that kept crashing when the autosave was turned on.
    Maja
