Activity Forums Apple Final Cut Pro Legacy FCP7 -Export QT NotWorking on other machines.
  • FCP7 -Export QT NotWorking on other machines.
    Posted by Patrick Jones on August 24, 2009 at 7:16 pm
    Hey guys – I did a Project and exported QT out and it works fine on my machine, but when I transfer to another computer, I get black screen and the audio. I both machines were iMacs, (G5 iMac and 1 new iMac) But not luck getting video. I did run through compressor at native size and although loss of quality – it did however play on the other computer. I never had this issue in FCS 1.
    thanks
    FCS 3 – MBP 2.93ghz 4gb RAM, 300gb 7200 Internal HDD, iStarUSA Dual Dock with (10) 1TB 3.5 Seagate Barracuda drives, and a couple 250’s Maxtors, and Seagates.
    Patrick Jones replied 17 years, 1 month ago 3 Members · 4 Replies
  • Jeremy Garchow
    August 24, 2009 at 7:36 pm
    Most likely the other machines don’t have the codec of your exported movie.
    DO those other machines have FCP installed?
    Jeremy
  • Shane Ross
    August 24, 2009 at 7:39 pm
    #48 – Cannot view DVCPRO HD or HDV or ProRes on my computer.
    Shane’s Stock Answer #48 – Cannot view DVCPRO HD, HDV or ProRes QT files on your computer.
    The DVCPRO HD, HDV and ProRes codecs only comes with FCP. If your computer does not have FCP installed, it cannot view these quicktime files. It doesn’t matter if it is a Mac or PC, without FCP installed, you cannot view these files.
    If you need to view ProRes material, you can download the ProRes decoder (mac and windows compatible) for ProRes
    https://support.apple.com/downloads/Apple_ProRes_QuickTime_Decoder_1_0_for_Windows.
    https://support.apple.com/downloads/Apple_ProRes_QuickTime_Decoder_1_0_for_Mac
    If your footage was captured as DVCRO HD you can buy the Calibrated DVCPRO HD decoder:
    https://www.calibratedsoftware.com/QDVCProHD.asp
    HDV, XDCAM? Calibrated has you covered too:
    https://www.calibratedsoftware.com/QXD.asp
    If you have MXF files from a P2 camera and you need to view the footage on a computer without FCP, you can download P2CMS from Panasonic:
    https://www.panasonic.com/business/provideo/p2-hd/downloads-and-updates.asp
    Or you need the other party to compress the footage into a format your computer can play, like H.264.
    Shane
  • Patrick Jones
    August 24, 2009 at 7:42 pm
    DVCPRO100 – is what I have been using for the past 5.5 years. on FCS 1 and now on FCS 3 – Im just going to File>Export>QuickTime – never had the issue before when sending someone a master to a computer which did not have a FCP on it, till now.
  • Patrick Jones
    August 24, 2009 at 7:44 pm
    Of course, maybe I did not notice it, because maybe I exported through compressor. LOL no idea now
