Activity Forums Apple Final Cut Pro Legacy FCP7 Even HDV sometimes does not play smoothly, is my mac broke?
  • FCP7 Even HDV sometimes does not play smoothly, is my mac broke?
    Posted by Ben Edwards on May 18, 2012 at 5:57 pm
    Hi, I have a 4*3Ghz macpro1,1 running Lion with 6GB memory and and a RAID 10 system (delivering around 60MS/s). I was having a problem with prores sometimes not playing smoothly and thought maybe the RAID was not fast enough (even though it is 4* faster than the ProRes bandwidth).
    Now I am editing a HDV project and occasionally the footage is briefly pausing, I am wondering if there is something wrong with my mac, or if I need to reinstall Mac OS X.
    Any advice woulds be spiffing;).
    Ben
    Ben Edwards – Freelance Picture Editor
    https://www.funkytwig.com
    Macpro1,1 2007 6GB RAM 2*2 3Ghz Xeon
    Ben Edwards replied 14 years, 4 months ago 2 Members · 5 Replies
  • Jerry Hofmann
    May 18, 2012 at 6:13 pm
    I make it a general rule to rebuild a startup disk about every year or any time there’s an upgrade to FCP or the OS. If not all sorts of weirdness seems to happen.
    If you’ve not done this in a while, you might be really surprised how much snappier the whole computer becomes.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Ben Edwards
    May 18, 2012 at 6:50 pm
    Thanks, top tip;). Is it possible to install application on another disk so you don’t have to reinstall everything?
    Ben
  • Ben Edwards
    May 18, 2012 at 6:54 pm
    PS, just like windows then;).
  • Jerry Hofmann
    May 18, 2012 at 6:56 pm
    Well one thing you can do to speed this process up next time is to create disk images which reside on a hard drive to install from. You can install the complete studio that way in about 30 minutes. You just mount them all at once.
    But keeping a clean system makes a big difference in your happiness, that’s for sure.
    Jerry
    Current DVD:
  • Ben Edwards
    May 19, 2012 at 5:11 pm
    OK, so I have done a fresh Lion install and installed FCP 7.0.3 and it still keeps on breafly stoping during playback. Maybe it is a hardware problem or maybe I should try Snow Leaperd.
    Ben
