Activity › Forums › Apple Final Cut Pro Legacy › FCP7 conversion to something that will work on PC
  • FCP7 conversion to something that will work on PC
    Posted by Chris Rust on November 2, 2013 at 3:42 am
    Hi All,
    OK, I’ve been shooting HD and HDV for a long time – editing non-linear since the late 90’s, and I’ve always worked on Macs. I don’t know why, but export formats still mystify me – especially when (trying to) plan(ning) for use in PCs. Everything seems to continue to change from month to month, etc. I have a project shot on HDV, edited in FCP7 ( HDV native). My client wants me to output a version onto 16gb flash drives for playback on PC laptops. My initial output was to QT – giving me a .mov file. The first test on a PC the .mov would not play. Downloaded QT for Windows, tried again – no luck. Then I tried converting to Mp4. This test was interesting, because the vid played back, audio was good, but the aspect was wrong. The picture had been squeezed. Then I tried converting to .avi – still no luck.
    What the hell am I doing wrong? Is Jobs haunting me from the grave? What do I have to do to complete my task successfully?
    Please help!!!
    Mahalo,
    crusty50@gmail.com
    Mark Suszko replied 12 years, 9 months ago 4 Members · 5 Replies
  • Mark Suszko
    November 2, 2013 at 4:12 am
    If you are talking about playing the file off of a thumb drive, if the files are high def, the drives may not have the transfer speed to play clean; are you having users drag the video to their desktops first? That way it plays off their hard drive instead.
    When I make files to share to unknown places, i use h.264 and windows media. Usually one or the other will work. But again, playing anything larger than a 30-second clip direct off a thumb drive may not play clean.
    Just my own opinion.
  • Rainer Wirth
    November 2, 2013 at 2:22 pm
    It depends on the software on a windows based PC.
    Nearly every PC has got a windows media player. Best format is WMV. If the PC has got a Quicktime player it will play quicktimes. The safest format is WMV 4:3 letterboxed. If the media player is an actual version it will also play H264(Mpeg4).
    By the way, we do all transcodings with Episode,
    cheers
    Rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
  • Rafael Amador
    November 3, 2013 at 10:55 am
    [chris rust] ” I have a project shot on HDV, edited in FCP7 ( HDV native). My client wants me to output a version onto 16gb flash drives for playback on PC laptops. My initial output was to QT – giving me a .mov file. The first test on a PC the .mov would not play. “
    SONY had the brilliant idea of making different the HDV codecs for the Mac and te PC.
    So HDV files are not cross-platform.
    [chris rust] “Then I tried converting to Mp4. This test was interesting, because the vid played back, audio was good, but the aspect was wrong. “
    Your choice of MP4 was correct.
    The distortion is a different issue.
    I guess you shoot HDV 1080, which is 1440×1080 HD Pixels, but the standard for HD is 1920×1080 SQUARED PIXELS.
    So when exporting, in the Geometry options, change to that specs; 1920×1080 Squared Pixels.
    if there is not an option for pixels (QT Player), just forget about and export 1920×1080.
    rafael
  • Chris Rust
    December 6, 2013 at 1:01 pm
    Thanks for your suggestions. Here are my results… Yes I did consider that the flash drive transfer speeds would not be fast enough and did try dragging the vid to the desktop — no difference.
    You say you use H264 AND Windows Media. If you don’t mind, please explain what you mean by that. I understand H264 is what I’m trying to get from Compressor. Windows Media? Are you talking about the player on the PC? or something else?
    I have also tried creating different versions using the QT Conversion settings and came up with some really ugly looking video.
    Going the h264 route: creates a file that is something on the order of 3X the size of the .mov (which was too big to begin with). Took forever — became such a size that I couldn’t get it onto a flash drive (11gb became 30+gb).
    Now, if necessary, I’ll take my machine to theirs and make a transfer via ethernet — but that doesn’t account for backup copies….
    Second, I made an MPEG2 version and stored it on DVDs. They would not play on the PC either. This is the way I have delivered to non-broadcast clients for years and has always worked. I use the DVD MPEG2 Best Quality 90 minutes and AAC audio settings.
    I looked at the flip4mac site and of course, the version I need is the most expensive. There must be some alternative to spending $180 to convert these files.
    Again I thank you for your suggestions and taking the time to respond to my query.
  • Mark Suszko
    December 7, 2013 at 6:08 am
    I meant .WMV format, using flip4mac, either exporting from the timeline directly, or from compressor. Other tools I use are FLCrunch and the ever-popular MPEG STREAMCLIP.
