Activity Forums Apple Final Cut Pro Legacy FCP7: change frame size within timeline-quick fix
  • FCP7: change frame size within timeline-quick fix
    Posted by Adam Chesbrough on October 22, 2010 at 4:20 pm
    I have 1080 prores (LT) footage, for some reason when I added the first clip to the timeline it changed the timeline and clip frame size to 1440×1080 and prores 422. If I change the setting to 1920×1080 the clips that are already on the timeline remain 1440×1080.
    All new footage inserted is 1920×1080, but I can’t simply reconnect and have the frame size change. I am looking for a one click fix as I have a ton of clips organized in different folders. Any ideas would be helpful. Thanks in advance.
    macbook pro 17″ i7, 8GB RAM
    esata external HD 7200RPM
    canon 5D mark II, 24-70mm, 50mm, 15mm fisheye, juicedink DT454, zacuto striker
    Tom Hinde replied 13 years, 2 months ago 3 Members · 3 Replies
  • Matthew Rogers
    October 22, 2010 at 4:40 pm
    Is is just an aspect ratio change? You should be able to highlight all the clips within that time line, right click, and choose remove attributes. Then check only the distort and motion boxes.
    That will remove the auto re size that FCP had originally done.
    -Matt
    Matthew Rogers
    Engine Room Edit
    Boston, Ma
    five13.net
    http://www.engineroomedit.com
  • Adam Chesbrough
    October 22, 2010 at 4:42 pm
    thanks for the reply, yeah its remove attributes and remove the distort…Thanks again.
  • Tom Hinde
    June 11, 2013 at 8:02 pm
    Dear Matt. I searched high and low for this….and wanted to say thanks for giving such simple and specific directions on how to do this. THANKS!!!!
