Activity › Forums › Apple Final Cut Pro Legacy › FCP7 Bizzare Error on Reconnecting Media
  • FCP7 Bizzare Error on Reconnecting Media
    Posted by Steve Smith on January 19, 2013 at 8:32 am
    I’ve got a huge and fiddly FCP7 project and unfortunately I accidentally powered down the external hard drive containing most of the media.
    On trying to reconnect the media I found that it didn’t seem to take to the ‘reconnect all files in relative path’ approach and I couldn’t pick up a number of files in one big hit.
    Now here’s the really strange part …
    I have clips on my timeline that are marked as ‘offline’ but they are behaving as if they are ‘online’. They load into the viewer and play on the timeline.
    I’ve rolled back to earlier (pre crash) autosave versions and they have the same problem but if I start a fresh test project I don;t have the problem.
    No amount of restarts has helped and I’ve rebuilt the prefs.
    I’ve accidentally twice before and I’ve been able to use the reconnect media function per usual.
    Anyone see a way through this?
    FCP 7.0.3
    OSX 10.6.8
    2.6 Ghz Intel Core Duo
    Tony Brittan replied 13 years, 8 months ago 4 Members · 6 Replies
  • Chris Tompkins
    January 19, 2013 at 3:16 pm
    rendered files/clips might be there while not being linked to the original…
    Chris
  • Steve Smith
    January 20, 2013 at 8:07 am
    Actually Chris, yes, that might explain some clips playing off the timeline but not the case of, say, my double clicking a source clip (on the timeline marked as offline and composited over another clip) loading back into the viewer in it’s original state including transparent area where the alpha channel is. To me that seems contrary to how FCP has always worked.
    So I think the mystery remains.
    Steve
  • Rafael Amador
    January 20, 2013 at 12:14 pm
    [Steve Smith] “Now here’s the really strange part …
    I’ve rolled back to earlier (pre crash) autosave versions and they have the same problem but if I start a fresh test project I don;t have the problem.”
    That’s just about the “Thumbnails”. FC haven’t refreshed them.
    I guess that if you delete them, FC will make a new set.
    You can also save the project with a new name.
    rafael
    http://www.nagavideo.com
  • Tony Brittan
    January 21, 2013 at 3:06 pm
    I had this happen just last week. Go to the thumbnails cache and delete them from inside the folder (don’t delete the actual folder). Then re-start FCP.
    Posted from iPad, please excuse typos!
    Tony Brittan
    Island Shore Productions
  • Steve Smith
    January 22, 2013 at 1:00 am
    Bingo! Deleted the two files in the ‘thumbnail cache file’ folder, restarted FCP and thumbnails are now correct.
    This succeeded where no amount of playing around with creating new projects and sequences and cutting and pasting data could.
    Tony and Rafael I can’t thank you enough … actually Rafael I wasn’t quite sure what you meant by ‘deleting’ the thumbnails but Tony’s post clarified that.
    Steve
    Steve Smith
    Producer/Director/Editor
  • Tony Brittan
    January 22, 2013 at 2:14 am
    Awesome! Glad I could help.
    Tony Brittan
