Activity Forums Apple Final Cut Pro Legacy FCP7: Best video processing settings for graded ProRes 4444 material/sequence
  • FCP7: Best video processing settings for graded ProRes 4444 material/sequence
    Posted by Kriss Rozins on June 6, 2012 at 9:24 pm
    Hi there!
    I have a clip that’s edited on Avid MC 6, graded in Apple Color and sent from there to FCP (using classc Send To -> Final Cut Pro method ).
    In FCP I started to check sequence settings for the particular sequence created by Color and some questions born in my mind.
    First of all – colour grading in Color was done in 12-bit internal depth and rendered to ProRes 4444 (which is a 10-bit codec). So the sequence in FCP is also a ProRes 4444 sequence. One thing that I noticed is that in Video Processing tab the 8-bit YUV method is chosen by default. Does it somehow affects the further workflow if I want to have my finished clip with 10-bit depth? If I choose any other of those settings, the green line appears on the sequence timeline.
    And the second thing is, when I checked the ProRes 4444 settings in Sequence Settings, the default color mode was Millions of colors. There is also ability to switch to Millions of colors+. AFAIK Millions of colors is usually 8-bit and the ”+” is usually used when alpha channel is present. Does FCP has different meanings for those settings?
    Kriss
    Ryan Knight replied 14 years, 1 month ago 2 Members · 1 Reply
  • Ryan Knight
    July 28, 2012 at 4:17 pm
    Great question! Did you find an answer?
