Activity Forums Apple Final Cut Pro Legacy FCP7 and OSX Maverick Working
  • FCP7 and OSX Maverick Working
    Posted by Steve Walker on October 23, 2013 at 11:38 am
    Only last week I thought I would risk installing 10.8 Mountain Lion so I could use Davinci Resolve 9. Previously alot of user comments about FCP7 not working had put me off the upgrading my 2009 Macbook Pro for a long time.
    Well that worked no problem so when OSX Maverick got released , and was free I thought what the hell. Lets do it.
    About 10 minutes into updating my 17″ 2009 8Gb Macbook Pro, Intel 3.06Ghz, I read Larry Jordans warning not to go down this road. I must admit, it did have me panicking for the next 90 minutes!
    Well it installed with one error message ‘SILICON IMAGE DRIVER INCOMPATIBILITY’ stating its being moved to an incombatibilty folder, where ever that is?
    That lost driver vSil3132_1.7.5 that I updated when I installed Mountain Lion, resulted in my external 2Tb Lacie via SATA II Express Card 34 not working, it could see the card but not the drive. I downloaded a very old driver for it v Sil3132_1.2.3.0 and hey presto I can now see my storage drives again!
    Now the big questions, will FCS3, Logic Audio 9, Davinci Resolve 9 Lite and Adobe CS5 all work again?
    Well I can report so far so good.
    All open upp ok, I threw a few shots on the timeline of FCP7, fiddled with some color and resizing, sent to compressor and watched the H.264 file back no problem.
    I’ll be probing a little further when I finish the Quantel edit shift!!
    Steve Walker replied 12 years, 9 months ago 7 Members · 12 Replies
  • 12 Replies
  • Matt Dunne
    October 23, 2013 at 2:03 pm
    Thanks for sharing Steve you’re much braver than I. I have switched to Premiere but still have some projects that require FCP7 so I’ve been biting my nails watching these forums.
  • Derek Dockendorf
    October 23, 2013 at 5:15 pm
    Thanks so much for this info. I did the install on my MBP last night and didn’t have any issues so I thought why not this morning and installed it on my MacPro workstation. As soon as the install finished I had the same Silicon Imaging driver problem and panicked as that was my two main working RAIDs. But with your help found the right driver and all is good in the world.
    FCP7 seems to be working like normal but I haven’t tried any AJA outputs yet. Premiere CC and X are screaming fast. I’m sure I’ll run into some compatibility issues here and there but hopefully they will get sorted out just like the eSata card.
  • Steve Walker
    October 23, 2013 at 5:40 pm
    I can also add that DVD Studio Pro 4 is working, so that’s the full FCS3 done. Also my Digital Heaven and Crumplepop FCP plug ins are all working fine.
    Only thing thats thrown a wobbler so far is Open Office 4.0.1. I just deleted a folder from the Library and got that back up and running.
    6 hours in and all’s just fine and dandy!
    Steve Walker
    BBC Senior Tech Op. Editor/Sound Mixer
    FCP-Quantel-Avid
  • Steve Walker
    October 24, 2013 at 3:40 pm
    Ocelot sounds like one of them companies from a Bond movie. The villainous ones that want to run the world. Not like Apple or MS.
    Note to add to a further incompatibility. I had to update the driver for my M-Audio Firewire 410 Audio/Midi Interface. I just got the latest one for OSX 10.7 or higher from M Audio site.
    All working fine again in FCP VO Tool.
    It was worth downloading for the tagging in Finder. It seems pretty stable so far folks.
    Steve Walker
    FCP-Quantel-Avid
  • Christopher Mcdonell
    October 29, 2013 at 1:17 am
    [Steve Walker] “It was worth downloading for the tagging in Finder. It seems pretty stable so far folks.”
    Awesome news. Who wouldn’t want the latest OS to run their EDL of choice? For me, I can’t wait to finally have tabs in Finder.
  • Christian Walter
    October 30, 2013 at 9:35 pm
    got it to run but could not install 7.03 update!
    + when i opened a project the colors were way off
    saturated and dark???
    any ideas?
    October 30, 2013 at 9:57 pm
    Did you lost QT Pro 7 along the way? Or is it installed too?
  • Michael Freund
    October 31, 2013 at 5:17 pm
    i installed maverick on 2011 imac 27 inch. works amazingly well, the second display support with each becoming its own desktop is fantastic. many other things as well. speed on virtually every operation in all apps is noticably faster. CS 5.5 great. FCP 7 no problem. soundtrack pro ditto.
    have not tried motion.
    compressor 4.0 does NOT seem to open. which i use every day. compressor 3.5 does open, which i haven’t used in years. so i guess i am back to operability.
  • Steve Walker
    November 1, 2013 at 1:49 am
    I already had the 7.0.3 update before upgrading to first Mountain Lion and then Maverick. It’s still behaving normally with multiple video layers, colour and effects.
    Perhaps Maverick messed up your display profile?? Try re-calibrating from System Preferences. Or perhaps it’s incompatible with 7.0
    Steve Walker
    FCP-Quantel-Avid
  • Christian Walter
    November 1, 2013 at 1:19 pm
    so i got it to work,
    the problemwas the external display was connected via hdmi,
    switched to thunderbolt and everything is working fine now,
    just not able to update to 7.03
