Activity Forums Apple Final Cut Pro Legacy FCP7 – A1 not playing.
  • FCP7 – A1 not playing.
    Posted by Jon Mitchell on November 30, 2013 at 4:35 pm
    Hey all, I’ve searched the forums and found several threads that were similar. I have tried everything I can think of plus the suggestions of some posters out here.
    So, all of a sudden, Final Cut decided to stop playing my narration track (A1). A2-A6 play just fine.
    I have tried these things (to no avail):
    • Restarting FCP
    • Restarting my Machine
    • Shutting Down My Machine
    • Trashing FCP Preferences
    • Ensured that the Audio is All 48k/16bit (wav)
    • Ensured that my audio clips are not muted, disabled, automated, or turned down in the audio mixer panel
    • Ensured that my audio files play in the Viewer/Source Monitor
    • Moved the audio to a different track
    • Disconnecting and Reconnecting Media
    Please help! Is this a corrupt FCP file or is there something I’m missing?
    Jon Mitchell replied 12 years, 9 months ago 3 Members · 5 Replies
  • Nick Meyers
    November 30, 2013 at 11:35 pm
    does the narration play when it is on A2 to A6?
  • Jon Mitchell
    December 1, 2013 at 3:07 am
    Nope, that’s what I meant when I said I moved it to another track.
  • Nick Meyers
    December 1, 2013 at 7:14 am
    sorry, i didn’t see that.
    odd. try opening a new project and importing the VO material into it.
    try it in the new sequence.
    nick
  • John Street
    December 1, 2013 at 6:34 pm
    Check to see if you accidentally hit the Clip Enable keystroke command sometime for that particular clip … select the clip and then go to the Modify menu and try the Clip Enable command to see if this fixes it …
    John Street
    http://www.inpoint.tv
    Mac OS 10.7.5, FCS 7.0.3, QT 7.6.6, Mac Pro 2x3GHz Quad-Core, 16GB Ram
  • Jon Mitchell
    December 2, 2013 at 3:10 am
    I discovered the issue. Appears to have been some Media Reconnect issues FCP wasn’t letting me know about. I had all the source files backed up on an NTFS drive (originally on a mac OSX journaled drive). When I reconnected everything with the backup drive (same file/folder structure) apparently the narration stuff went AWOL – even though it appeared as connected and displayed waveforms.
    I opened it today and it prompted me to reconnect and then everything worked fine. I had to click reconnect on the file in the timeline before it would work, but it played the audio just fine.
    Thanks for the suggestions!
    –Jon
