Activity Forums Apple Final Cut Pro Legacy FCP6.04 running very slowly
  • FCP6.04 running very slowly
    Posted by Dale Suffridge on August 14, 2008 at 5:17 pm
    Hi Guys.
    Here are the facts.
    –Brand new Mac Tower – running OS 10.5.4 with 8 cores and 4 GB RAM
    –Just brought machine to life, installed FCP 6.04
    –Nothing else running
    –One sequence open in FCP (with settings of DVCPRO HD 720p60, which is the native format of the majority of files that will be used – footage from Panasonic P2 cam)
    –Screenshot of timeline available here.
    –Other elements in the timeline are HD vid elements from Digital Juice
    The problem I am having is:
    Just to render 50 seconds of this timeline for playback is taking one hour. It has taken me days to get just the first 1min 12sec done due to this. At this rate, I will never be able to finish the projects I will be working on.
    (Also, this one hour time is just to render the VIDEO portion. The audio has already rendered. So even though there are multiple tracks in the audio portion of the timeline, I do not think that this is an issue – unless I am wrong)
    Is this a memory setting limitation of FCP (of which I have already maxxed out at 2560mb)? Is it a possible problem with the MAC? Is there a setting somewhere that can be changed (Mac or FCP)?
    Any feedback, questions for clarification, etc. would be incredibly appreciated.
    Thanks so much,
    Dale Suffridge
    Video Producer
    Kennesaw State University
    Mike Weber replied 18 years, 1 month ago 7 Members · 10 Replies
  • 10 Replies
  • Dale Suffridge
    August 14, 2008 at 6:06 pm
    I also forgot to add two possibly important facts:
    –All the footage and elements are housed in an external 88 firewire 1.5 TB Drive.
    –The scratch disc is now located on the Towers Main HD.
    Don’t know if these matter or not, but wanted to add them.
    Thanks.
  • Paolo Mugnaini
    August 14, 2008 at 6:48 pm
    Yeah it seems a little excessive…..
    Have you tried to check the render settings in your timeline settings window?
    Also how many plug ins, if any, do you have on your video?
    If everything is native you should not have any issues.
    Before you started the new project did you do an easy set up?
    I can’t think of anything else, I hope it helps.
    Paolo
    FCP 5.1.4 – PowerMac 2.2 Dual – 4.5 Gb Ram
    1Tb G-Raid2 – 2 1Tb Lacies- CUBASE SX3
  • Dale Suffridge
    August 14, 2008 at 7:04 pm
    Thanks Paolo.
    If you meant the sequence render settings, then yes. I have tried lowering them, but it only seemed to make it take longer.
    I don’t have any plug ins. But the HD elements from Digital Juice are mov files that are from a different size (1920×1080) and compressor setting (animation) than the recorded files from the P2 cam (960×720 and compressor DVCPRO HD 720p60).
    As for the easy setup, I think I did. I set it to DVCPRO HD 720p60. But I have been through what I know of the settings with a fine tooth comb since them.
    I am still hoping that there is something that I do not know about in the guts of FCP or the Mac that will facilitate a better speed.
    Dale Suffridge
    Video Producer
  • Walter Biscardi
    August 14, 2008 at 9:37 pm
    [Dale Suffridge] “–All the footage and elements are housed in an external 88 firewire 1.5 TB Drive.
    –The scratch disc is now located on the Towers Main HD. “
    Never EVER set the Scratch disc to the Macintosh HD. This should ONLY be assigned to a media array.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Lawrence Gray
    August 15, 2008 at 3:21 am
    Hmm… I have an irritating Mac as well. It seems very slow. My problem I’ve been told is the way I’ve set up my four terrabyte system… I just did it as one big Raid volume. Apparently a dumb idea. You need a separate System Disk and as the man said above, move the scratch disk to a separate disc.
    I haven’t got round to reformatting and reinstalling everything yet… boy am I looking forward to that! But essentially if after doing that and i’m still having problems of this nature, it means the Mac isn’t working as it should.
    Since all the tests i’ve done indicate the Mac is OK, then everything points to the disk configuration.
    Lawrence Gray
  • Michael Sacci
    August 15, 2008 at 3:07 pm
    Dale,
    One thing that I would recommend putting into your workflow is to convert all the DJ clips to the same settings as your seq/footage. You can do it in the background with Compressor and then bring in those clips. That way every time you make a change to the sequence where those clips are they want have to be rendered. I bet they are also the wrong (different frame rate).
    Did you change the scratch disc settings?
  • Dale Suffridge
    August 15, 2008 at 3:46 pm
    Michael,
    Changing the DJ clips to match the vid clips and sequence setting (DVCPRO HD720p60) was the idea I came up with late yesterday. But after using Compressor conversion set to those settings, I ran into a problem when plugging them back in to the timeline. Compressor had taken away the alpha.
    I have the least experience with Compressor of all the software I work with. In my initial look through Compressor 3.0.3, I could not find a setting that would give me both the settings I need – DVCPRO HD720P60 and Alpha. Do you happen to know of a way to get both those settings?
    NOTE: The DJ files are native .mov files. But those native files do not come in with alpha. You have to use the “Juicer” from digital juice to render them. And it only gives you the following settings to choose from:
    and
    But can Compressor do the work that the “Juicer” is doing, but with more choices (with hopefully one of those being the DVCPRO HD720P60 and Alpha)?
    Or do I have any other options to get these files into the same format before getting them into the timeline?
    Oh, and yes I did change the scratch disc. Thankfully, even though I had never heard not to have it on your main HD, I had always been keeping it on an external drive. And I had only changed it yesterday to see if it sold help speed things up. But now I know never to do that again. 🙂
    Thanks so much for any more thoughts you might have.
    Dale Suffridge
  • David Cheok
    August 15, 2008 at 4:47 pm
    Change your sequence settings to Prores422.
  • Dale Suffridge
    August 15, 2008 at 7:02 pm
    Hi David.
    That was the first change I made when the whole problem arose. But it did not help. I will try again and see if anything else I have applied in the meantime might have helped that scenario.
    Dale
  • Mike Weber
    August 15, 2008 at 11:03 pm
    Dale –
    This is a long shot, but it could be a RAM issue. I was experiencing performance problems with my brand new Mac Pro where I was having to render things that I didn’t on my G5 or iMac even.
    I began to suspect my RAM. As it turned out, I had enough RAM (Two 2 GIg modules = 4 GB total), but this did not match Apple’s recommended configuration. Take a quick look at this Apple document:
    https://support.apple.com/kb/TS1957?viewlocale=en_US
    The Mac Pros have 2 “risers” inside, and Apple is recommending that each riser has either 2 or 4 DIMMs, for a total of 4 or 8 DIMMS, all of equal size. I installed four 2 DIMMS, two on each riser, and suddenly it’s like my hands were untied, and my performance improved immensely. I now have 8 Gig of RAM, though I suspect if I had four 1 Gig modules installed, for a total of 4 Gig, my problem would’ve gone away as well.
    So I don’t know if this helps your situation, but something to look at.
    Mike
