Activity Forums Apple Final Cut Pro Legacy FCP.6, where’s Boris 3D?
  • FCP.6, where’s Boris 3D?
    Posted by Chris Gorman on June 7, 2008 at 6:08 am
    I don’t see Caligraphy/Boris 3D after upgrading to fcp.6 Is it hidden somewhere?
    I wanted to use scrolling text with the control options available in Boris 3D, but can’t Boris. Any comparable substitute, or how do I get it back? The fcp scrolling text is too limited.
    Chris Gorman replied 18 years, 3 months ago 2 Members · 2 Replies
  • David Roth weiss
    June 7, 2008 at 6:48 am
    Chris,
    The message and the link below are from the nice people at Boris, not from me. Hope it helps. It worked for several others.
    David
    Here’s the long and the short of it. The four bundle files that make up the Boris titling application called Calligraphy rely on the operating system to flag them as bundles instead of folders. In some cases (like if you update FCP or your OS) these bundles get mislabeled as folders, therefore FCP can not “see” them and you loose your titles. The fix for this is simple. Below is a link to where you can download a set of new bundle files that identify
    themselves as bundles. Once you’ve downloaded them, locate the FCP plugins folders here: Hard Drive>Library>Application Support>Final Cut Pro System Support>Plugins. In there you should find the four FOLDERS named: “Text Scrambler.bundle”, “Title 3D.bundle”, “Title Crawl.bundle” and “Vector Shape.bundle”. Delete those FOLDERS and replace them with the FILES you just downloaded.
    That’s it.
    https://www.borisfx.com/download_files/CalligraphyForFCP.dmg
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Chris Gorman
    June 7, 2008 at 7:09 am
    thank you, I’ll download those. In the meantime, I started playing with the Master Templates, new in fcp6. If you’ve use those and have any advice, pros/cons, let me know. Thanks.
