Activity Forums Apple Final Cut Pro Legacy FCP6 transition effects bug
  • FCP6 transition effects bug
    Posted by Greg Nosaty on June 15, 2007 at 8:15 pm
    I have discovered an odd bug using short transitions in FCP6.
    It started when I dropped an 8 frame “G Film Flash” transition to my timeline and it appeared as a 4 frame transition. So I change the duration in the browser to 16 frames and then re-apply it and the duration as 8 frames. It consistently applies the effect with half of its specified duration.
    So I tested a bunch of Apple, CHV, CGM and Nattress transitions and they all experience the same issue. Any transition with a duration of 29 frames or less and FCP6 cuts the length in half.
    Try it for yourself and see if you get the same results.
    cheers,
    greg
    cheers,
    greg
    Carsten Orlt replied 19 years, 3 months ago 4 Members · 4 Replies
  • David Roth weiss
    June 15, 2007 at 8:27 pm
    Greg,
    You probably need to trash your prefs or pram. This definitely does not happen here. I just tested it.
    David
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • Tom Wolsky
    June 15, 2007 at 8:29 pm
    Can’t reproduce that. Anything unusual about the media you’re using or how you’re applying the transitions?
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Greg Nosaty
    June 15, 2007 at 9:09 pm
    [David Roth Weiss] “You probably need to trash your prefs or pram. This definitely does not happen here. I just tested it.
    David”
    Your right, I just tested it on my laptop and it works fine. I guess a prefs trash is in order.
    thanks.
    cheers,
    greg
  • Carsten Orlt
    June 15, 2007 at 11:06 pm
    could it be that the transition you having problem with doesn’t have enough handle length on one side (either in or out)?
