Activity Forums Apple Final Cut Pro Legacy FCP6 on Leopard – DCDP and keyboard problems
  • FCP6 on Leopard – DCDP and keyboard problems
    Posted by Tony Van mellaert on December 24, 2007 at 11:41 am
    I installed a fresh copy of Leopard on a second drive, installed FCPstudio2 and did all the upgrades, installed the new Kona driver, and now there are some strange things happening:
    1) I cannot use Digital Cinema Desktop Preview anymore, the option has dissapeared. I can only use it for the main window.
    2) Every time I open FCP I have to select the keyboard layout again, it seems to forget the choice I’ve made. (I use azerty-belgium)
    When I start up my Tiger on the same machine I have no problems of this sort.
    I tried trashing the preferences and Plist, upgraded the X1900XT firmware… no use
    Does anyone have an idea?
    Thanx, and merry X!!
    I use a Mac Pro 8-core, Radeon X1900XT, 2X ACD23
    Lu Nelson replied 17 years, 11 months ago 5 Members · 7 Replies
  • 7 Replies
  • Jeremy Garchow
    December 24, 2007 at 6:04 pm
    Did you run software update?
  • Tony Van mellaert
    December 24, 2007 at 9:56 pm
    Yes, all of them
  • Leo Celi
    January 13, 2008 at 12:46 pm
    hi,
    i have the same problem with the keyboard layout every time i restart FCP, the digital desktop preview works ok
    did you solved the problem?
    thanks
  • Amund Lie
    January 23, 2008 at 1:11 pm
    Look in this folder:
    MacintoshHD/library/quicktime
    throw out:
    DesktopVideoOut.component
    Then replace it with an older version (the one I used was from April 2005). You should use a previous version from before you installed Leopard. If you don’t have one I can mail it to you.
    Amund
    Oslo, Norway
  • Tony Van mellaert
    February 11, 2008 at 8:44 pm
    I just tried it, I used a DesktopVideoOut.component file from an old Tiger backup, but nothing has changed. I tried reinstalling everything and noticed Digital Cinema Desktop Preview was working fine untill I installed the AJA Kona driver. Afterwards the option Digital Cinema Desktop Preview and the one with “full screen” have disapeared. Only the one with “main” is left.
    So it must have something to do with the Aja driver…
  • Tony Van mellaert
    February 12, 2008 at 4:52 pm
    I just installed Leopard update 10.5.2, but the problem is still there…
    Actually all the bugs are still there:
    – export using compressor from FCP : Final cut pro generated an error!
    – option Digital Cinema desktop preview disapeared.
    – Keyboard layout disapeares.
    If you have the same problems as I do, maybe we can compare hardware to see what we have in common that could be causing this problem.
    I use a Mac Pro 8-core 3Ghz, XT1900, Aja Kona Lhe…
  • Lu Nelson
    October 22, 2008 at 12:03 pm
    I haven’t noticed a keyboard problem here yet, but had nearly the same scenario is you — until I simply opened the Displays System Preferences panel, and re-selected the settings for my two displays. I think the system was not recognizing them properly, although it was displaying info on them. It might be a question of persistent settings problems, like what you sometimes get with the “Startup Disk” item. Anyway I restarted and now DCDP is available.
    Lu Nelson
    Berlin, Germany
