Activity › Forums › Apple Final Cut Pro Legacy › FCP6 Nested Sequences w/ Multiclips = SLOW
  • FCP6 Nested Sequences w/ Multiclips = SLOW
    Posted by Sean Oneil on July 12, 2007 at 1:02 am
    I don’t know if this is a bug or what. I’m trying to work with a nested sequence. The original sequence has multiclips in it.
    The simplest tasks, like splicing or trimming a clip gives me the spinning beach ball for like 10 seconds before it executes the command. It’s horrible.
    Has anyone else tried this? Similar experience?
    I’m just using regular DV25 codec. Not ProRes or anything crazy (God forbid). I’m not using “mixed formats” (sequence settings match the media). It’s a Mac Pro Quad 2.66ghz.
    Sean
    Christian Hoepfner replied 19 years, 2 months ago 3 Members · 5 Replies
  • Jerry Hofmann
    July 12, 2007 at 11:40 am
    Have you collapsed the mulitclips?
    Jerry
  • Sean Oneil
    July 12, 2007 at 4:35 pm
    Yes I have collapsed everything. The issue persists whether the clips are all collapsed or uncollapsed.
    Sean
  • Jerry Hofmann
    July 13, 2007 at 12:36 am
    mmmm. if you don’t nest them, do things speed up?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Sean Oneil
    July 13, 2007 at 5:15 pm
    [Jerry Hofmann] “mmmm. if you don’t nest them, do things speed up?”
    Yes, everything is fine on the original sequence.
    Sean
  • Christian Hoepfner
    July 19, 2007 at 2:37 pm
    I’ve run into the same problem yesterday. Except that I now get the spinning beachball of death when I try to trim in every sequence in my project, not just in the sequence with the nested stuff.
    When running system maintenance and trashing FCP prefs yiedled no results, I saved the project with a new name. I then opened the original project again and restored it to a version prior to the time when started working with the nested sequence. Everything works fine – and I can trim again without that spinning pest.
    However, I lost a bunch of render files and of course all the edits I made after working with the nest.
    I’m running FCP HD 4.5 on a 1.5 Ghz G4 Powerbook with 1.5 gig memory with G-drives.
    Project is NTSC DV.
