Activity Forums Apple Final Cut Pro Legacy FCP6 & Motion – Dissolve Puzzlement
  • FCP6 & Motion – Dissolve Puzzlement
    Posted by Tom Daigon on August 22, 2007 at 2:57 am
    OK…heres a real stumper…any suggestions appreciated…
    1. Build a simple series of cuts in s FCP6 sequence.
    2. Go to the second cut (duration of 3 sec) and send to Motion
    3. Build a multilayer title treatment/open.
    4. Save and return to FCP.
    5. Try to dissolve out to cut 3…but only 1 frame diz is created since the Motion clip is too short (only 3 sec).
    6. Open the clip in Motion and extend all the elements to 4 sec. Save then return to FCP. Confirm in the browser the clip is now 4 sec.
    7. Apply a diz…still only 1 frame..but we know that there
    is enough of a clip now to allow the diz.
    Whats up with this? It is something editors need to do quite often. What do you do when a client requests this?
    Tom
    Tom Daigon replied 19 years, 1 month ago 3 Members · 4 Replies
  • Walter Biscardi
    August 22, 2007 at 9:32 am
    Did you double check the clip in the timeline. Is it also showing up as 4 seconds?
    One easy thing to do is simply throw the Motion element onto a separate video track and apply the dissolve to the end of that clip. Place the element you’re dissolving into right below it. I do this all the time.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Tom Daigon
    August 22, 2007 at 11:38 am
    Thanks Walter. Yes, the clips does show up as 4 sec. in the timeline. The second track solution is a good work around.
    I guess 12 years on the DS helped me forget how I used to do
    multipe track diz on the Composer when it first came out.
    I do appreciate the insight!
    Tom
  • Pat Defilippo
    August 22, 2007 at 6:56 pm
    Hi guys,
    Does the clip in your timeline show a duration of 4 seconds as currently edited? If so, you’ll need to make the Motion clip 3:15 in order to do a 1 second dissolve to the next clip. Also, double-check that your Clip 3 has at least 15 frames of heads. This is assuming you are applying a dissolve that is centered on the edit (and does not begin or end there).
    I hope this helps.
    -Pat
    G5 Quad 2.5 Desktop with 4GB Ram, 500GB HD & Fiber Card ~
    30″ Cinema Display & 17″ Sony SVGA ~
    Swift Data 200 Internal 1.6TB SATA II RAID 0 ~
    AJA Io LA ~
    Final Cut Studio ~
    Sony UVW-1800 Beta-SP ~~~
    P D Post Productions, Inc. ~
    TV~DVD~VHS~CD~WEB
    for Corporate Communications, Commercials, Infomercials, Television Programs, Family Occasions since 1983 ~
    E-mail PD@PDPost.com ~
    Website http://www.PDPost.com ~
    Business/Cell Phone (847) 275-5671
  • Tom Daigon
    August 22, 2007 at 7:44 pm
    The clip was extended in Motion fron 3 to 4 sec, which then was confirmed in the FCP browser (and by checking its length on Trk2 of the timeline), so yes…I definately had enough tail. The diz I wanted was to START at the edit point,
    (not in the middle or end at the edit point) which would work with clip 3 just fine…except it didnt.
    Still a mystery , but now with a Walter Workaround.
    Thanks for the response though.
