Activity Forums Apple Final Cut Pro Legacy FCP6 and opical flow slomos
  • FCP6 and opical flow slomos
    Posted by Alan Lacey on September 26, 2007 at 6:39 pm
    Dear gurus,
    Am I right in believing that FCP6 now has shake’s optical flow as an option for the speed changed, and time remapped clips?
    If this is so how does one access that in preference to the old method of frame blending?
    Thanks for the info
    Alan in PALland
    Mark Raudonis replied 18 years, 11 months ago 4 Members · 8 Replies
  • 8 Replies
  • Uli Plank
    September 26, 2007 at 6:45 pm
    No, that’s not in FCP, but Motion3 or Compressor.
    Hope this helps,
    Uli
  • Mark Raudonis
    September 27, 2007 at 4:02 am
    Just saw a demo of this tonight at the Los Angeles FCP user group meeting.
    Tip of the day if you’re going to use optical flow: It generates HUGE render files. Depending on your format (SD or HD) these files can be many ,many gigabytes. There’s an option to delete this renders. Use it frequently for completed work or you’re gonna run out of space.
    The results look great.
    Mark
  • Alan Lacey
    September 27, 2007 at 5:25 am
    Thanks guys – very helpful.
    Alan
  • Rafael Amador
    September 27, 2007 at 10:07 am
    [Mark Raudonis] “It generates HUGE render files. Depending on your format (SD or HD) these files can be many ,many gigabytes. “
    Mark,
    I don’t understand this. The render files don’t use the same codec that you are working with (like in FC)?
    Rafael
  • Mark Raudonis
    September 27, 2007 at 1:13 pm
    Let me clarify: Not renders per se, but analysis “Cache” files.
    Go to preferences, click on “Cache”. At the bottom you’ll see settings for “Optical Flow retiming”. They added a button for “Delete retiming cache” because these files grow to immense proportions very quickly. It’s recommended you delete these as soon as you’ve made your timing choices.
    Mark
  • Rafael Amador
    September 27, 2007 at 1:30 pm
    Thanks Mark, now I got it. I just installed FCS2 few days ago and I haven’t had time to open the applications except FC.
    Cheers,
    Rafael
  • Alan Lacey
    September 27, 2007 at 4:01 pm
    that’s interesting Mark, is Shake the same?
    I wonder what makes the cache files so enourmous? Surely it’s not creating motion vectors for each pixel???
    Alan
  • Mark Raudonis
    September 27, 2007 at 5:58 pm
    This toolset (Optical flow) comes from Shake, so I’m guessing it operates in a similar manner.
    I don’t know the science behind why it’s so big, but it is!
    Mark
