Activity Forums Apple Final Cut Pro Legacy FCP5 vs FCEHD
  • Walter Biscardi
    February 1, 2006 at 9:02 pm
    [Matt Jones] “What’s the quality difference (CODEC) between FCP5 and FCEHD? Is FCEHD a HDV native App? Can it Be? Is there any difference in rendering times during capture, editing and output?”
    FCEHD is limited to DV codecs only, like HDV. It is the exact same codec as in FCP 5.
    FCP 5 can use all codecs such as DVCPro HD (far superior to HDV) and of course uncompressed formats.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Shane Ross
    February 1, 2006 at 9:28 pm
    FCE HD captures DV as DV/NTSC…same codec as FCP. It captures HDV as AIC (Apple Intermediate Codec), while FCP captures HDV in its native format.
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • Matt Jones
    February 1, 2006 at 9:36 pm
    So if FCE captures HDV with the AIC, I would edit in AIC, and then output back to my Z1 in what CODEC? Is there another AIC to HDV transcode that has to happen first? Roughly how long does that take? What’s the quality difference between the AIC and the HDV native codec? Can you SEE it on a 1080i display?
    Thanks.
  • Walter Biscardi
    February 1, 2006 at 10:50 pm
    [Matt Jones] “What’s the quality difference between the AIC and the HDV native codec? Can you SEE it on a 1080i display?”
    The BEST way to edit HDV is via 10bit Uncompressed HD. That’s the only successful way I’ve heard to get the best quality footage.
    My guess is that you will definitely see a degredation of the HDV format by capturing to the AIC codec. I honestly didn’t know that FCEHD did not support HDV codec natively.
